machining victor-X manifold for extra set of injectors
Old Feb 23, 2007 | 02:27 AM
ImportMotorSpec's Avatar
Default machining victor-X manifold for extra set of injectors
Does anyone on here do or know where to i can get the extra set of injector bosses machined in and the holes tapped for the mounting bolts on a victor-X manifold for a GSR. I need to add these and i already have my manifold port matched from last year. So i would like to stick with this manifold. Thanks in advance.
Old Feb 23, 2007 | 02:43 AM
DaveF's Avatar
Default Re: machining victor-X manifold for extra set of injectors (ImportMotorSpec)
you can buy a "drill bit" for injector boss's from kinsler fuel injection.
or you can also buy injector boss's and weld those onto the manifold.
Old Feb 23, 2007 | 08:43 AM
onefstek's Avatar
I have done it on a couple manifolds for two race cars. There is not much material there to play with.
It also takes a different fuel rail that you have to buy.
BTW I have a fuel rail if you need one.
JDMswagSerf
Dec 12, 2013 10:58 PM
rwasmund
Feb 23, 2007 04:25 AM
Xemu
Nov 14, 2006 10:30 AM
Roid
Oct 26, 2006 06:17 PM
[B16]HiGhCaM
Jun 30, 2002 08:53 PM
