JDM b16/ how much should it be making and how to get more
Old Feb 22, 2007 | 10:24 PM
1_slow_crx's Avatar
Default JDM b16/ how much should it be making and how to get more
jdm b16 1st gen w/ chiped pr3 (kenji) -- for now
4-1 no name header
Cold air intake
2.4 exhaust with high flow cat
supertech springs/ and ti retainer
stage 2 brian crower cams
how much should i be making with a good tune?
what should i look to rev too?
. my current rev limit is 9000k. but
i dont take it past 8300 til i dyno and ge tune.
Old Feb 22, 2007 | 10:37 PM
1_slow_crx's Avatar
Default Re: JDM b16/ how much should it be making and how to get more (1_slow_crx)
im only looking to make 155-160 hp. nothing crazy. . .
if 130whp is stock.. i would like 30 whp over stock.
i also have a FPR , and walbro 255 fuel pump which should help on the tune..
what do you think it will make HP and TQ?
and those of you with similar set ups what do you rev to and make power at?
i have seen similar rev to 9.5k. but that seems a bit much.
also.. is a head gasket worth it ? to up compression ?
Old Feb 22, 2007 | 10:42 PM
doood's Avatar
been there done that
put it on the dyno and find out
Spoonie09's Avatar
Nobody could ever give you an accurate answer. Depending on how beat the engine really is factors in alot. Being that your engine is a 1st gen b16a with your mods I could only see it at 130 to the wheels to 150 max. But the only way you will know is to take it down to your local dyno.
Old Feb 22, 2007 | 10:50 PM
1_slow_crx's Avatar
Default Re: JDM b16/ how much should it be making and how to get more (Spoonie09)
its a very clean motor. the clip i got it from had 45km's on it.
and i have only put 5k miles on it since.
but 1st is lower compression.. so who knows.
Old Feb 23, 2007 | 11:04 AM
1_slow_crx's Avatar
Old Feb 23, 2007 | 12:56 PM
kartman5's Avatar
You may want to do some work on the head. New cams, port & polish, better
header etc. This would be a good start. If you do not already have it, you'll
need some way to dyno tune your car - Hondata S200, Chrome etc.
Good luck!
Old Feb 23, 2007 | 06:18 PM
b16nonoy's Avatar
take it to the dyno..I believe some places will run it..if you want to see only how much HP and TQ yyou have...around here it is only $50 I believe to do 1 run and see your numbers
Old Feb 23, 2007 | 06:20 PM
smileycvc's Avatar
Default Re: JDM b16/ how much should it be making and how to get more (b16nonoy)
anybody with a dyno offered to the public will run it. He already said he has stage 2 cams. I say stop asking people how much power your gonna make and take it to a dyno, or better yet get a butt dyno
krc91987
11
Jan 18, 2012 07:35 AM
bluelight_92
Aug 22, 2006 07:19 PM
JDMjdawg
Dec 10, 2003 11:34 PM
nsxmatt
Aug 17, 2003 05:37 PM
granada_sun
Apr 17, 2003 11:21 AM
