Moved my battery to the trunk! Drove the CRX...finally!
Old May 20, 2002 | 10:16 PM
Sonny's Avatar
Default Moved my battery to the trunk! Drove the CRX...finally!
I'd driven my CRX a grand total of 8 miles before today...the exact distance from the previous owner's house to my garage. I swapped in a new water pump, new timing belt, a 95 Civic CX radiator, some new tires (dayum...you shoulda seen the old ones! ), and finally got the battery into the trunk.
It feels great to finally drive the car...I was getting real sick of looking at it on jackstands for 3 months. hehe
The engine has 195k on it and it still runs like a champ. The car ran pretty strong...it's gonna be wicked fast with the ZC turbo.
Here are pics of the battery move:
http://www.muller.net/sonny/crx/battery
Sonny
[Modified by Sonny, 7:16 AM 5/21/2002]
Old May 20, 2002 | 10:58 PM
MilanoRex's Avatar
Default Re: Moved my battery to the trunk! Drove the CRX...finally! (Sonny)
you should get the sealed battery ASAP... that doesnt look very safe.
Old May 20, 2002 | 11:05 PM
Sonny's Avatar
Default Re: Moved my battery to the trunk! Drove the CRX...finally! (MilanoRex)
Yeah...it is totally unsafe. Fumes aside, it would do a number on ya if went flinging around the inside of the car in an accident. Yikes.
The only reason it is there was so that I would have a reference point for the cables. I drive the good ole gutless Nissan pickup to work and the CRX is the project. I'll either get a sealed battery box (and bolt it all to the chassis) or an Optima or DynaBatt battery.
Sonny
Old May 21, 2002 | 12:24 AM
ImportHatch's Avatar
I was thinkin of strappin my battery to my chest with the top popped off the battery...I'm gonna try it out and let ya know...
Yager-
Old May 21, 2002 | 12:33 AM
rice_classic's Avatar
Default Re: Moved my battery to the trunk! Drove the CRX...finally! (ImportHatch)
sniff sniff.. what's that smell? sarcasm
Old May 21, 2002 | 06:53 AM
xci_ed6's Avatar
Default Re: Moved my battery to the trunk! Drove the CRX...finally! (rice_classic)
mmm, hydrogen gas!
I think when I do that I'll use a 4Ga amp kit and a fuseable link with a sealed mower battery.
-Dustin
Old May 21, 2002 | 06:58 AM
89 CRX SI's Avatar
Default Re: Moved my battery to the trunk! Drove the CRX...finally! (Autocratic_1st_Gen)
yeah man i know how you are ive had my rex for 4 months and never driven it only drove it about 2 miles from old owners house to mine. but next month after WW and New wheels im getting her insured
Old May 21, 2002 | 07:11 AM
WuShu's Avatar
New User
Default Re: Moved my battery to the trunk! Drove the CRX...finally! (89 CRX SI)
Im relocating my battery in the trunk of the rex and im keepin my spare tire, talka bout a pain in the *** to find a place to mount it on the sides! no room whatsoever! And whats with these bastards who make these battery boxes, this thing was huge!!!!!!!!!!! my little battery fits in there like a rain drop in the ocean
Old May 21, 2002 | 07:15 AM
markedOO1's Avatar
Default Re: Moved my battery to the trunk! Drove the CRX...finally! (HondaCRX)
I had to cut some wood blocking for mine...but it did make a nice little place to hold zip ties, a screwdriver..etc hehe.
Old May 21, 2002 | 08:15 AM
WuShu's Avatar
New User
Default Re: Moved my battery to the trunk! Drove the CRX...finally! (marked001)
yeah you could probably hide a small cheater bottle in there.
Old May 21, 2002 | 10:57 AM
Cryptopsy's Avatar
Sonny, sonny sonny, please tell me that you are gonna fix your little problem and do things the right way? I mean, common...
Old May 21, 2002 | 11:00 AM
Sonny's Avatar
Default Re: Moved my battery to the trunk! Drove the CRX...finally! (SoulflyCRXsi)
Man, you guys are harsh. Did you read this paragraph that I wrote?
NOTE: This battery is not a sealed-gel type, so this configuration is not safe. It is only temporary.
Don't worry...I'll fix it! It will be fully strapped down, too. I was just anxious to share pics.
Sonny
Old May 21, 2002 | 01:28 PM
Urban Business
Guest
Posts: n/a
how did the radiator swap go? any mods required. weight diferences etc
Old May 21, 2002 | 05:14 PM
Sonny's Avatar
Default Re: Moved my battery to the trunk! Drove the CRX...finally! (TorteX)
The radiator swap had a couple of issues:
1) The radiator cap on the CX radiator is right on top of the radiator. On the stock radiator, it is offset to towards the firewall via a "neck". After the radiator is installed, you won't have access to the cap. You basically need to install a remote filler cap in the hose between the radiator and the head. No biggie there.
2) The thermoswitch that is located in the bottom of the stock radiator does not plug into anywhere on the CX radiator. That's because this switch was moved to the block on the later engines. I'm working on a way to make this work. Without it, basically you must manually control the fan.
3) The fan's electrical plug is different. The CRX plug is white and round. The CX rad plug is rectangular and grey. You can either put an OBD1 connector on the wiring harness or put an OBD0 style connector on the fan.
Sonny
[Modified by Sonny, 2:15 AM 5/22/2002]
hkacrkil
Acura TL, RL & ZDX
Apr 10, 2015 02:06 PM
NOFX
21
Jun 30, 2011 02:58 PM
h22mark
Aug 24, 2004 03:14 PM
ridiculous
Nov 13, 2002 11:52 AM
AussieK24
Aug 21, 2002 09:34 AM
