Spark plug pics,Ls/vtec Gapping?
Old Feb 22, 2007 | 06:10 PM
skiracer8148's Avatar
Default Spark plug pics,Ls/vtec Gapping?
well i changed my sparkplugs today and took some pics.the car was boggey.and still is slightly even with new plugs.my car is ls/vtec and all oem parts.the check engine light is not on.what should i gap my new plugs too right now there at .44.thats what i read for stock b16.or should i bump it up to .50 gsr stock?
Old Feb 22, 2007 | 06:25 PM
one slow coupe's Avatar
Default Re: Spark plug pics,Ls/vtec Gapping? (skiracer8148)
do it .032"
good for all motor
Old Feb 22, 2007 | 07:02 PM
95DxSi-R2
Guest
Posts: n/a
those are way rich
Old Feb 22, 2007 | 07:05 PM
SkoundrelUSA's Avatar
cute little bastard
whats your compression ratio?
I'd leave it at stock gap or maybe a little smaller at .40-.42
Old Feb 22, 2007 | 07:27 PM
hoya_10fintec's Avatar
.035"~.040"
Old Feb 23, 2007 | 03:20 AM
yeh i thought those look way too rich,im running a phearable.net ecu
Old Feb 26, 2007 | 12:46 AM
mtber's Avatar
Default Re: (skiracer8148)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skiracer8148 &raquo;</TD></TR><TR><TD CLASS="quote">yeh i thought those look way too rich,im running a phearable.net ecu</TD></TR></TABLE>
Pull your intake air temperature sensor out of your intake manifold or your intake & ensure that the tip of the sensor is not melted.
I have seen several people improperly wire up there vehicles causing a IAT sensor to melt and report very low iat temps causing the vehicle to run rich.
A common mistake is to burn q31 on the ecu by mixing up the 2 wire plugs on the engine harness!
(Intake air temperature sensor should be a green wire & red/yellow stripe wire.)
Old Feb 26, 2007 | 05:57 AM
hey theres my guy.yea i will double check that
Old Mar 2, 2007 | 02:22 PM
i went outside today and checked and yes the plugs were switched and the tip of the iat sensor was melted,what iat sensor can i use?from any b series?
Modified by skiracer8148 at 6:45 PM 3/2/2007
Old Mar 2, 2007 | 03:23 PM
Brycen's Avatar
my hatch was doing the samehting till i changed the spark plugs, still did it then i noticed that the CEL code was for the map sensor i looked and the strut bar was hitting it and casued it to shave off the lip it had for the clip to attach to so i just zip tied the plug to the map sensor haha.
hondaguyef
Apr 13, 2005 01:01 PM
TrnsferErr
13
Apr 5, 2005 09:22 AM
cifer6425
Apr 10, 2004 06:15 AM
mickey513
Feb 23, 2004 05:41 PM
