gas gauge?
just filled a full tank today, but for some strange reason my gauge still read empty after i filled it.
after driving it for a while i started getting some bars, but after 5 miles of driving it hasn't even reached half tank, when it should've read full from the get go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s200045302 »</TD></TR><TR><TD CLASS="quote">this normally happens when you don't shut the car off. did you leave it running when you filled up? if so try shutting it off next time. </TD></TR></TABLE>
People leave their car on when they fill up? I've never seen or heard of that. Isnt that dangerous? I'm sure it would throw a check engine light also if u left the car running. Maybe u mean the accessory position? Anyhow. To the OP, I have had the same problem. Sometimes the bars with show up immediately and other times it will take a few miles.
car was off. last time i filled up engine was off with accesorries on and the gauge was going up as i was filling it, this time it just showed empty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchedeg »</TD></TR><TR><TD CLASS="quote">car was off. last time i filled up engine was off with accesorries on and the gauge was going up as i was filling it, this time it just showed empty.</TD></TR></TABLE>
That does sound kinda weird. I've personally experienced it now showing as totally full but atleast 3/4+ tank until I drive around for a bit then it will gradually kick up to full. Maybe its the cold weather or something
the car must be completely off - key out of the ignition. I had the same problem on my MY02, took it to the dealership and they had a service bulletin on it and there was nothing wrong. There is a sort of delay in the system to make up for the movement of fuel in the tank so that the gauge doesn't move around a lot. Hope that helps.
sfmaniq
Honda Civic (2001 - 2005)
Jun 24, 2008 11:08 AM
PinoyCivic
Oct 4, 2006 06:13 PM
