86 prelude Si starting problem its unexplainable no reason for it PLEASE HELP????????
Old Feb 22, 2007 | 04:53 PM
davidcrx89's Avatar
Default 86 prelude Si starting problem its unexplainable no reason for it PLEASE HELP????????
so 86 si prelude 242,000 owned by old people ran great well taken care of stopped it went in came out about ten minutes later and it wont start. checked timing belt, spark, new plugs, fuel, injectors, injector resister box, ecu for codes non. SO if it has timing, spark, and fuel. it should run right. OH and i made sure there was nothing wrong with the cam.
So i am stumped and so is all of my friends that have also looked at it.
makes no sense
Old Feb 22, 2007 | 05:07 PM
Prudz_lude's Avatar
Default Re: 86 prelude Si starting problem its unexplainable no reason for it PLEASE HELP???????? (davidcrx8
gas?
Old Feb 22, 2007 | 05:19 PM
davidcrx89's Avatar
yeah it has gas and even when i spray starting fluid down the intake still nothing oh and i checked the compression although a little low its dead even all the way accross @ 125psi even across all 4
Old Feb 22, 2007 | 05:38 PM
GtechPro's Avatar
Does it turn at all? Or is there no response when you turn the key?
Old Feb 23, 2007 | 07:08 AM
davidcrx89's Avatar
it turns over fine and it will put every now and then but thats it
Old Feb 23, 2007 | 04:07 PM
davidcrx89's Avatar
anyone????? could it be the ecu if it was bad though would it give spark and fuel??
Old Feb 23, 2007 | 04:44 PM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
check the main relay under the dash to the left of the steering wheel. when it gets hot or maybe if you had the heat pumping, the solder points on the relay disipate and the car wont start. Mine did this over the summer and all I had to do was re-solder the ends and everything has been fine since then.
Old Feb 24, 2007 | 06:14 AM
davidcrx89's Avatar
accept when the relay goes bad that stops spark and gas right and i have all that
Now if the ecu were bad would it still get all that stuff gas spark injector pulse ECT...
Old Feb 24, 2007 | 03:45 PM
davidcrx89's Avatar
well i tried a different working for sure ECU and it puts more than it did but still wont start
Old Feb 24, 2007 | 05:14 PM
roller3804's Avatar
new dizzy? ignition switch?
Old Feb 24, 2007 | 08:01 PM
davidcrx89's Avatar
Default Re: (roller3804)
see that the wierd thing it all works it gets spark fuel timing is on and it has compression. i tried new plugs,ecu,checked the cam to make sure it was not broke,checked the injectors to make sure they were pulsing and even a different injector resistor box.
So i ask if it has spark, fuel, timing, and compression shouldn't it start?
and it ran great before it was shut off came back about ten minutes later and this is what happened wont start??
Thanks for all the help
Old Feb 24, 2007 | 09:20 PM
roller3804's Avatar
ignition switch?
Old Feb 24, 2007 | 10:43 PM
BlueLude84's Avatar
thats what i was thinkin'.
si_motor_spt
Aug 17, 2022 10:52 AM
LostStranger
Feb 7, 2015 01:17 PM
1994preludevtec
Jul 14, 2011 10:43 AM
FuzzyGreen
Jan 8, 2003 07:48 PM
