Water Pump.... Type-R?
Old Feb 22, 2007 | 03:34 PM
simonsays's Avatar
New User
Default Water Pump.... Type-R?
Searched but didn't come up with anything, will a type-r water pump work with a JDM B18C????????
Old Feb 22, 2007 | 03:38 PM
tha_badguy's Avatar
just because its type r doesnt make it special...
Old Feb 22, 2007 | 03:39 PM
NBPdEeCeE's Avatar
* B A N N E D *
Default Re: Water Pump.... Type-R? (simonsays)
I could've sworn I read somewhere that all the B-series water pumps are the same...
Old Feb 22, 2007 | 03:51 PM
stealthmode62's Avatar
Default Re: Water Pump.... Type-R? (ViSioNxBoY)
It will work, and it's worth 30 show points if you tell the judges.
Old Feb 22, 2007 | 03:53 PM
turbociviccoupe's Avatar
Default Re: Water Pump.... Type-R? (stealthmode62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote"> It will work, and it's worth 30 show points if you tell the judges. </TD></TR></TABLE>
thats more than a k20 swap....im getting one for sure
Old Feb 22, 2007 | 03:57 PM
pdiggitydogg's Avatar
b18c (1 and 5) are the same
not all b water pumps are the same - thats obd2 oil pumps
the difference in water pumps has to deal with the number of teeth on the gear
Old Feb 22, 2007 | 04:05 PM
simonsays's Avatar
New User
well jhp has a type r one for 100 i'm not putting anything but oem on my car and i can only find oem ones for over 100 so i figured i'd go with tha. thanks for clowning on me guys if anyone nows a site where i can get a oem gsr for cheap let me know!
Old Feb 22, 2007 | 04:26 PM
the go for under 100 all the time on ebay
brand new
oem
and for the second time, all b18c water pumps are the same
do not spend more money for itr....
Old Feb 22, 2007 | 04:30 PM
Default Re: (pdiggitydogg)
$97.62
http://www.acuraautomotivepart...ormal
Old Feb 22, 2007 | 04:35 PM
simonsays's Avatar
New User
awesome, thanks guys will hit up ebay
Old Feb 22, 2007 | 07:11 PM
gabebauman's Avatar
Default Re: (simonsays)
Call up the stealership and see what it costs local.
Old Feb 22, 2007 | 07:22 PM
hoya_10fintec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ViSioNxBoY &raquo;</TD></TR><TR><TD CLASS="quote">I could've sworn I read somewhere that all the B-series water pumps are the same... </TD></TR></TABLE>
ANY B-series water pump will physically fit but B16 water pump(the gear) is smaller than B18C whatever water pump gear.
Old Feb 23, 2007 | 11:49 AM
simonsays's Avatar
New User
the STEALERSHIP wants $176
Old Feb 23, 2007 | 11:59 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: (stealthmode62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote">$97.62
http://www.acuraautomotivepart...ormal</TD></TR></TABLE>
thats an oil pump lol
GSR Water pump $100
Old Feb 23, 2007 | 01:50 PM
doood's Avatar
been there done that
Default Re: (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoya_10fintec &raquo;</TD></TR><TR><TD CLASS="quote">ANY B-series water pump will physically fit but B16 water pump(the gear) is smaller than B18C whatever water pump gear.</TD></TR></TABLE>
no. go look up part numbers for them. same thing.
Old Feb 23, 2007 | 01:57 PM
unknown0001's Avatar
If you go with ITR water pump you will need an ITR timing belt I belive.
Also, the ITR water pump has less fins compared to the others, so when it's moving the coolant, the less fins the more complete flow. The more fins the more it will 'swish' the coolant around.
Old Feb 23, 2007 | 02:22 PM
doood's Avatar
Default Re: Water Pump.... Type-R? (Mr.RHTuner)
what part of all b series vtec water pumps are the same are some of you people not understanding?
only the b nonvtec pumps are different. and you would use the timing belt that corresponds to the block. b18c block = b18c belt. b16 block = b16 belt.
Old Feb 23, 2007 | 02:33 PM
Default Re: Water Pump.... Type-R? (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">what part of all b series vtec water pumps are the same are some of you people not understanding?
only the b nonvtec pumps are different. and you would use the timing belt that corresponds to the block. b18c block = b18c belt. b16 block = b16 belt.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=114358
Here's the numbers(all rated at 6,000rpm
B16A water pump 140qpm
B17A water pump 140qpm
B18C water pump 148qpm
B18B water pump 148qpm
For those who huff butane:
qpm = quarts per minute
So if the b-series vtec water pumps are the same...then how could they flow different? what don't YOU understand?
I have also checked up this information previously with an acura tech when I was trying to find the highest flowing oil pump and water pump for my builds in the past
Old Feb 23, 2007 | 02:45 PM
doood's Avatar
b16 pump p/n - 19200-P72-013
gsr pump p/n - 19200-P72-013
itr pump p/n - 19200-P72-013
if they were any different, why do they all have the same p/n's?
check for yourself
http://www.acuraparts247.com/catdisplay.jsp
http://www.slhondaparts.com/
Old Feb 23, 2007 | 03:27 PM
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">b16 pump p/n - 19200-P72-013
check for yourself
http://www.slhondaparts.com/</TD></TR></TABLE>
Uh....I checked for a Del Sol VTEC and got a different part number...
http://www.slhondaparts.com/br...EC%29
Old Feb 23, 2007 | 03:32 PM
doood's Avatar
Default Re: Water Pump.... Type-R? (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">Uh....I checked for a Del Sol VTEC and got a different part number...
http://www.slhondaparts.com/br...EC%29</TD></TR></TABLE>
odd, i checked it for an '00 si. they seem to be from different manufacturers as well.
edit: after doing a little more checking it seems the obd1 gsr pumps also have different p/n's and the 92-93 gsr shares the pump with the del sol vtec you posted. so maybe there could be some slight differences.
Old Feb 23, 2007 | 03:38 PM
cute little bastard
yeah i checked that too. pretty weird
Old Feb 23, 2007 | 07:06 PM
Default Re: (doood)
no. go look up part numbers for them. same thing.</TD></TR></TABLE>
no, double check your parts book or get an updated one.. or the #'s might be right but the gear part IS different... this I've compared myself and said to myself, WTF?
I don't rely on parts book 100% myself 'cause it's been wrong before...
Modified by hoya_10fintec at 8:19 PM 2/23/2007
Old Feb 23, 2007 | 08:08 PM
b16nonoy's Avatar
yea hAhA..that was the thread I made a little while back..the pumps are all the same..here is the thread
https://honda-tech.com/zerothread?id=1896404
Old Feb 24, 2007 | 09:32 AM
Default Re: Water Pump.... Type-R? (b16nonoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16nonoy &raquo;</TD></TR><TR><TD CLASS="quote">yea hAhA..that was the thread I made a little while back..the pumps are all the same..here is the thread
https://honda-tech.com/zerothread?id=1896404</TD></TR></TABLE>
well... we were talking about WATER PUMPS not oil
EJ8_Man
Apr 13, 2011 09:04 AM
all-mtr-teg
19
Apr 21, 2008 08:44 PM
ismael-robert
Jun 15, 2006 11:32 AM
dfoxengr
Dec 15, 2003 06:31 PM
tegbuilder
Oct 30, 2003 09:46 PM
