brake problems with 92 civic dx hatch
Old Feb 22, 2007 | 03:06 PM
92eg6b16's Avatar
Default brake problems with 92 civic dx hatch
hey i posted a few weeks back with a intermittant brake issue...i've replaced pads, rotors, calipers, booster, master cylinder, hoses, and booster check valve and still as i drive the pedal gets tighter and tighter as i go until the brakes are closed and i have to use full throttle to keep the car moving and when i stop both sides in the front are smoking hot literally...any suggestions as to what could be goin on i replaced the master cylinder and booster about a month before everything else and the problem started after installing new pads rotors and calipers...
Old Feb 23, 2007 | 02:51 PM
92eg6b16's Avatar
Default Re: brake problems with 92 civic dx hatch (92eg6b16)
bump
Old Mar 1, 2007 | 02:27 PM
92eg6b16's Avatar
bump
Old Mar 1, 2007 | 03:35 PM
Nongan's Avatar
did you bleed the brake lines?
Old Mar 1, 2007 | 07:05 PM
dwigman's Avatar
Default Re: brake problems with 92 civic dx hatch (Nongan)
Have you tried checking the emergency brake.
Old Mar 1, 2007 | 07:35 PM
JDM-SPECS's Avatar
Default Re: brake problems with 92 civic dx hatch (dwigman)
did u grease everything that u were suppose to when u did the pads....sounds like its seized on the caliper....or the piston is seized in the caliper bore.
Old Mar 1, 2007 | 09:53 PM
elmo908's Avatar
Sounds like air is stuck in the calipers. I would try to bleed your brakes out very thoroughly if I were you. Remember to start at the brake that is furthest from the master cylinder and work your way towards it. At least that is the routine I used on my 2 other cars and it worked very well.
Old Mar 5, 2007 | 08:31 AM
92eg6b16's Avatar
Default Re: (elmo908)
i've bled the system quite a few times...we just got a bg brake system flush yesterday so i'm gonna try that and i haven't checked the emergency brake...it doesn't really work that well the back brakes probably need to be adjusted bad but the fronts are the only two that are closing up on me
Old Mar 5, 2007 | 09:12 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (92eg6b16)
You may want to check the pedal height adjustment. If the pedal is out all the way, but still slightly pressing on the brakes, they will drag. As the brakes become hotter & hotter, things start to expand. This could be why your brakes drag more & more as you go.
I did a rear disc conversion about 2 years ago. For some reason, it caused my pedal height to change, and made the brakes drag all the time. They didn't get tighter as I went like yours, but it was not a good thing...
Old Mar 7, 2007 | 03:03 PM
92eg6b16's Avatar
Default Re: (94eg!)
i've adjusted that too backed out as far as i could....it doesn't do it on my way home from work only on the way in thats why its confusing the hell out of me...the motor is a b20 vtec turbo skunk 2 intake manifold anybody had any issues with that maybe a vacuum problem...it didn't do it for about the first 3 months the setup was in the car only when i replaced pads and rotors cause they were starting to grind
Old Mar 7, 2007 | 07:50 PM
94eg!'s Avatar
#1 Super Guy
Loved
Then your best bet is to flip the calipers up & make sure the slide pins arn't frozen. If they are, the outer pad will most likely be dragging.
I have heard of this problem being related to a mad brake booster, but you said you already replaced that...
Old Mar 9, 2007 | 01:12 PM
92eg6b16's Avatar
Default Re: (94eg!)
i'm about to just replace the booster again then and see if thats the problem i've gettin tired of foolin with it i've been messing with it since early december...track opened last week and i can't even run lol its killin me...might just get another shell and say screw it
Old Mar 10, 2007 | 12:56 PM
kos99ngel's Avatar
Also have a civic 92 dx I have a problem with my brakes. After driving the car for about 3 weeks without washing the car every time I hit the brake my foot goes to the floor and the ******* car doesn’t want to stop its hard for the car to stop but it’s been doing this for the past year I have replace my brake pads they are new but it still does the same thing after driving the car for about 3 weeks I have trouble stopping I notice that right after I wash my car it goes away I think it’s because I wash off the powdery stuff that the brake pads release do I need to get better brake pads or can it be my rotors?
Old Mar 10, 2007 | 04:30 PM
kos99ngel's Avatar
help plz
NayborhoodJohnny
Oct 21, 2009 02:01 AM
pimpdd101
Nov 29, 2008 09:08 PM
92eg6b16
Feb 5, 2007 08:04 PM
veejay
Jul 24, 2001 09:39 AM
