Rod bearing tangs...direction?
Old Feb 22, 2007 | 12:24 PM
pdiggitydogg's Avatar
Default Rod bearing tangs...direction?
Ive read that the tangs need to face the exhaust side....is that for BOTH rod and cap tangs?
If it is to prevent a spun bearing, wouldnt it make more sense to have the rod tang face the intake side and the cap tang to face exhaust, due to the rotation direction?
Please help....Im confused
Old Feb 22, 2007 | 03:55 PM
97grnrs's Avatar
Default Re: Rod bearing tangs...direction? (pdiggitydogg)
they both face the same way if i remember right.. i would not mix them up if u havent already,
Old Feb 22, 2007 | 08:42 PM
SlowReaction's Avatar
Default Re: Rod bearing tangs...direction? (97grnrs)
Do not swap the directions of the tangs. Both tangs should face the exhaust side. Rods and caps are honed to spec with both tangs on the same side. If you turn the caps then the bearings wont sit correctly.
Old Feb 23, 2007 | 09:48 AM
99B16Si's Avatar
i think he means if he installed the rod backwards
Old Feb 23, 2007 | 06:05 PM
no just wondering
both of mine are on the exhaust side, but i was just thinking about it
EG-SIXV-TEC
Jul 5, 2013 05:20 AM
mondo45psi
Apr 16, 2009 07:02 PM
pdiggitydogg
Feb 22, 2007 04:29 PM
unknown0001
Jul 3, 2005 07:48 AM
Sonny
Aug 23, 2002 08:06 PM
