tune for break in period
i just finished my build it is as follows:
ls/vtec...bottom end
bored .020 over
eagle rods
entire rotating assembly balanced
je 11:5:1 forged pistons
je rings
arp mainstuds
arp headstuds
ctr crank pulley
gsr windage tray and oil pan
type r water and oil pumps
topend...
gsr head
hondata intake manifold gasket
3 angle valve job
supertech springs
skunk2 retainers
ferrea high comp. valves
skunk2 intake mani.
RMF header
buddy club spec 4s
rc 310 or 440
driveline...
jdm b16 y1
....i was just wondering when i go to start up, how should i tune it to break it in? i have a stock gsr ecu but iknow that it is not mapped anywhere close to the same as my setup..... i want to tune w/ crome....so should i send my p28 away to be chipped and wait to street tune it before start up. no one around here tunes cars though....im stuck
bored .020 over
eagle rods
je rings
arp mainstuds
arp headstuds
ctr crank pulley
topend...
gsr head
3 angle valve job
supertech springs
skunk2 retainers
skunk2 intake mani.
RMF header
buddy club spec 4s
rc 310 or 440
driveline...
jdm b16 y1
dude the closest tuner to me is hybrid dynamics in PA. plus i need to drive the car there not trailer it there....(its like 100 miles away)i wanna break the engine in first before going up there to tune
yea that sounds like a good idea, but i dont want to tow it to the dyno only for something to be wrong with it(thats more time i got to pay for )....i at least want to start it up and check for leaks and take it for a test drive.....u know waht i mean
There are several guys on here that mod/tune ecu's and/or will burn chips for you with basemaps. If your ecu isn't socketed already, it will have to be anyways so get it off to one of those guys right away and send them your engine specs. They will socket the computer and use Crome to burn a chip for your motor with as close of a program as they have in their library to yours.
From: MoonSHINE Metropolis, .FL. Run Free, North America
you should be alright(given that your chipped p28 has a base map applicable for your set-up).the motor will run but it wont be tuned.If your looking to break the motor in before dyno session,try your best to avoid detonation and keep an attentive ear(high octane/airfueling,ignition retard/map). hop ona wide-band and keep an eye on your mixture. check the condition of your spark plugs ina while too.
to me,your set-up is pretty agressive.
try to see if you can get someone to burn you a basemap and question what has been altered in the maps aswell(opt. for richer fuel maps and probably slightly retarded ignition maps for temporary).
Basically you wanna run the motor ,huh? The basemap is gonna be broad,even if it runs a little rich(poofs of black smoke),that'll be alright temporarily. Please tell me you've got a wideband??looks like your gonna need it.Good luck
Modified by MotorSpecies ver1.6 at 5:07 PM 2/23/2007
Modified by MotorSpecies ver1.6 at 5:09 PM 2/23/2007
Modified by MotorSpecies ver1.6 at 5:10 PM 2/23/2007
