Which Oil is best?
Old May 20, 2002 | 07:57 PM
DCtwoR's Avatar
Default Which Oil is best?
Just curious what kind of oil everyone uses. I use Mobil 1. Is there a better oil?
Old May 20, 2002 | 07:58 PM
Hybrid ctr's Avatar
Default Re: Which Oil is best? (RedlineR 106)
The majority here uses Mobil 1
01PYITR's Avatar
Default Re: Which Oil is best? (Hybrid ctr)
Oh no not this again, Mobile 1.
Old May 20, 2002 | 08:05 PM
Jet Phi's Avatar
Old May 20, 2002 | 08:08 PM
DCtwoR's Avatar
Default Re: Which Oil is best? (01PYITR)
ha, was this an earlier post....oops.....
B2FiNiTY's Avatar
I use mobil 1 10w30 but may switch to castrol GTX 10w30 cause the mobil 1 is too expensive.
Old May 20, 2002 | 08:14 PM
EagleR's Avatar
_______
https://honda-tech.com/zerothread?id=163845 This is all 10 pages of it, have fun...
[Modified by EagleR, 12:15 AM 5/21/2002]
Old May 20, 2002 | 11:03 PM
TypeR_853's Avatar
Default Re: Which Oil is best? (EagleR)
hahaha...yeah and for some reason it keeps going and going and .............
Old May 21, 2002 | 12:01 AM
Honda F1's Avatar
Default Re: Which Oil is best? (ridge racer 2)
I've been using Mobil1 10w 30. But after reading up on things a bit I am thinking of switching to Valvoline Max Life. It supposedly has better anti-wear characteristcs and is cheaper to top it off. My car just burns Mobil1 way too fast, so a switch is worth a try.
Old May 21, 2002 | 12:05 AM
B2FiNiTY's Avatar
Default Re: Which Oil is best? (HONDAF1)
I use water.
Old May 21, 2002 | 12:17 AM
01CWITR's Avatar
Default Re: Which Oil is best? (B2FiNiTY)
i think Redline should be one o the best around
Old May 21, 2002 | 01:20 AM
TypeR_853's Avatar
redline is pretty good...you should read the 10+ page post...that will probably answer all of your questions and then some...lol
Old May 21, 2002 | 02:47 AM
itr0032's Avatar
Mobil 1
Old May 21, 2002 | 03:37 AM
kenji's Avatar
25 Year Member
Default Re: Which Oil is best? (itr0032)
An oil you may want to consider is Schaeffer's 7000 blend with soluble molybdenum disulfide. It costs less than Mobil 1 and in my opinion is a better oil for what most of us use our ITRs for. I use it in my ITR.
http://www.bobistheoilguy.com is a great site for oil information.
Also, the person who posts by the name of Bror, Jace has a wealth of good oil information.
Schaeffer's products are not available in stores. Go to http://www.schaefferoil.com for more info on their products.
-kenji
Old May 21, 2002 | 03:51 AM
Dave-ROR's Avatar
omg not this again.
castrol gtx, will never use mobil 1 again. the b18c has a damned good amount of miles on 5000-7500mile oil changes with gtx, makes more power for the mods it has then 90% of the graphs i've seen, doesn't burn much at all (0.25 quart/day at sebring vs 1-2 qt/day mobil 1 in other integras). and after switching to mobil 1 in my boosted car it spun a bearing.. and after asspenny switched to mobil 1 he spun a bearing in his r... coincidence? just random occurences i'm sure, but surely doesn't make me wanna spend an outrageous amount of $$ on oil i have zero good experience with and a lot of bad experience with... D's car also burns less after dumping his mobil 1 addiction.
[Modified by 01_Yeller_ITR, 2:08 PM 5/21/2002]
Old May 21, 2002 | 04:23 AM
hooptie157's Avatar
Default Re: Which Oil is best? (01_Yeller_ITR)
I'm still using the factory recommended 5w30 is that bad?
Old May 21, 2002 | 04:36 AM
Dave-ROR's Avatar
Default Re: Which Oil is best? (hooptie157)
not imo.. some people will say yes but you live up north where 5w (when it's cold) isn't bad and 30 when warm is in the south we can use single weight oils
Old May 21, 2002 | 05:06 AM
Flux's Avatar
Please read this thread: https://honda-tech.com/zerothread?id=163845
Old May 21, 2002 | 05:18 AM
Willard's Avatar
Which Oil is best?
Duff beer has a new oil that will be released soon... keep an eye open for it.
Old May 21, 2002 | 05:26 AM
Cosworth's Avatar
Default Re: Which Oil is best? (Willard)
Does anyone run Amsoil? They are supposed to out-perform every oil in the U.S. The only down fall is that it's very expensive!
Old May 21, 2002 | 05:33 AM
MPH's Avatar
MPH
New User
I switched from 5w30 Mobil 1 to Castrol GTX 5w30 also. BTW, with the Mobil 1 I had to add a little bit about once a month, and with the Castrol, haven't burnt a drop.
Old May 21, 2002 | 05:50 AM
Dave-ROR's Avatar
Default Re: Which Oil is best? (Cosworth)
i use it in the mexican car's tranny..
Old May 21, 2002 | 06:04 AM
J28S's Avatar
New User
Redline! Tests have been performed (note: Not by Redline) to look at which oil gives better protection. On ITRs, the big problem is A) Heat, and B) Bearings (info from OPM and King Motorsports). The test looked at everything including heat. The results, Redline had the highest heat (thermal) protection than any other oil. Does anyone know how hot it get in the combustion chamber? Granted Redline is expensive, but think of it as added insurance. If you don't believe me, you can ask Phat S, SVT Cobra, Shultz, Catch 22 (I think they were all in on the eMail that was forwarded to us). My $.02, take it for what it is worth...
Old May 21, 2002 | 06:10 AM
Flux's Avatar
Default Re: Which Oil is best? (J28S)
I have been thinking of switching to Redline. Is there anywhere we can see the results of these tests you ae talking about?
Old May 21, 2002 | 06:19 AM
J28S's Avatar
New User
Default Re: Which Oil is best? (Flux)
Sure! I'll shoot an eMail to those guys. One of those 4 guys actually sent me the information...
