clutch slipping
Old Feb 22, 2007 | 06:00 AM
DarrinM's Avatar
Default clutch slipping
My clutch seems to slip when i press all the way down the the gas pedal.Doees this mean i need a new clutch? or could it be anything else?
Old Feb 22, 2007 | 06:26 AM
~sp33~'s Avatar
EFB055
Try tightening your clutch cable first (assuming your clutch is cable, and not hydrolic).
Old Feb 22, 2007 | 06:37 AM
Jonknee's Avatar
Default Re: (~sp33~)
Some dudes on here think it may be rear main seal leaking oil
Old Feb 22, 2007 | 09:45 AM
DarrinM's Avatar
Default Re: (Jonknee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonknee &raquo;</TD></TR><TR><TD CLASS="quote">Some dudes on here think it may be rear main seal leaking oil</TD></TR></TABLE> I think that could be there is some oil how can i fix that? and ill will see if my cable is tight thanks for the help
Old Feb 22, 2007 | 10:33 AM
Jonknee's Avatar
Default Re: (DarrinM)
Well im just quoting what other people say, but i dont see how oil can leak from one side of the flywheel into the clutch disk, Maybe your clutch cable needs to be adjusted man.
Old Feb 22, 2007 | 10:34 AM
ef8 h0!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~sp33~ &raquo;</TD></TR><TR><TD CLASS="quote">Try tightening your clutch cable first (assuming your clutch is cable, and not hydrolic).</TD></TR></TABLE>
Old Feb 22, 2007 | 10:43 AM
DarrinM's Avatar
where do i adjust it at ? is it on the transmission?
Old Feb 22, 2007 | 11:08 AM
ef8 h0!'s Avatar
Yes, its on the trans. Well not on it but right above it. Do a search for tightening your clutch and you'll find some help there im sure.
michael15
Oct 31, 2008 07:54 AM
-Championship-
Jul 2, 2006 09:48 PM
I8ayellowcrayon
Aug 23, 2004 07:18 PM
4DRmafia
Jun 10, 2004 06:58 AM
jondancer
Jun 9, 2003 02:57 AM
