88/89 Dimmer Switch?
Old May 20, 2002 | 07:54 PM
ruiner17's Avatar
Default 88/89 Dimmer Switch?
Just a simple question here. I need to know the order of these wires that go to the dimmer switch.
The color of the wires are:
• Black - ground
• Red/Black - to dash lights
• Red - power
I just need to know which ones go to which pins. I've tried it before, but have either blown fuses or fried the switch.
back of dimmer switch
88/89 crx or civic - any help is thankful!
[Modified by ruiner17, 8:56 PM 5/20/2002]
Old May 21, 2002 | 06:44 AM
keithv's Avatar
Default Re: 88/89 Dimmer Switch? (ruiner17)
i'll try to check on this for you tonight...
Old May 21, 2002 | 07:11 AM
89 CRX SI's Avatar
Default Re: 88/89 Dimmer Switch? (breaka_1_9)
I would geuss at :
A) ground
B) interior lights
C) +
but dont trust me its just a educated guess hee
Old May 21, 2002 | 08:18 AM
xci_ed6's Avatar
Default Re: 88/89 Dimmer Switch? (89 CRX SI)
Get out a multi meter (VOM) and check it. The ground will have continuity with both, but on one the resistance will change. The one where the resistance is constant is the +12V, The one with the changing resistance is dash lights, and the other one is ground.
-Dustin
Old May 21, 2002 | 04:59 PM
ruiner17's Avatar
Default Re: 88/89 Dimmer Switch? (Autocratic_1st_Gen)
I would try the multi meter, but i don't have one nor do i have access to one. THanks for the heads up though.
Old May 21, 2002 | 05:07 PM
ruiner17's Avatar
breaka_1_9 thanks...if you could check, that would be awesome.
Old May 22, 2002 | 06:17 AM
keithv's Avatar
doh, i forgot. i'll try again tonight.
ek_b16
Jan 3, 2010 09:35 AM
biochemist
May 1, 2008 06:34 PM
egblack94
Jun 18, 2007 06:39 PM
MrPotatoeHead
Feb 21, 2005 04:25 PM
TegBen
10
Nov 19, 2003 09:06 PM
