oil burns fast, oil in spark plugs
Old Feb 22, 2007 | 02:09 AM
kreative's Avatar
Default oil burns fast, oil in spark plugs
honda civic 98
radiator gets hot only driving a couple of mins.
oil burns really fast.
spark plugs have oil around it.
thanks.
Old Feb 22, 2007 | 02:35 AM
mikeycivic's Avatar
Default Re: oil burns fast, oil in spark plugs (kreative)
time for new motor
Old Feb 22, 2007 | 12:26 PM
kreative's Avatar
Default Re: oil burns fast, oil in spark plugs, radiator hot
new motor? its only 90k.. please someone with any sense please reply..
Old Feb 22, 2007 | 12:37 PM
SiYouLater's Avatar
check the spark plug grommet for oil leaking into the cylinder head.
Old Feb 22, 2007 | 12:45 PM
krazyhmongboi's Avatar
try changing the gasket seal..in the kit usually comes with valve cover gasket and spark plug seals..i had a similar problem
Old Feb 22, 2007 | 12:53 PM
kreative's Avatar
Default Re: (krazyhmongboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazyhmongboi &raquo;</TD></TR><TR><TD CLASS="quote">try changing the gasket seal..in the kit usually comes with valve cover gasket and spark plug seals..i had a similar problem</TD></TR></TABLE>
its a 98 ex with a 00 si motor. seems like the radiator is hot just going
a few blocks. its the same radiator that went with the ex motor. so is changing
the radiator, to an si radiator or better, help to cool the engine more efficiently?
Old Feb 22, 2007 | 12:54 PM
kreative's Avatar
Default Re: oil burns fast, oil in spark plugs (SiYouLater)
theres no leak from the head.
Old Feb 22, 2007 | 01:20 PM
blu3g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kreative &raquo;</TD></TR><TR><TD CLASS="quote">theres no leak from the head.</TD></TR></TABLE>
kraziehmongboi is telling how to fix the oil on your spark plug.
Rich Vee
Mar 22, 2018 12:50 PM
kmeng
Sep 14, 2010 08:02 AM
01blackcivic
Honda Civic (2001 - 2005)
10
Jan 27, 2009 11:34 AM
Sean @ ESG
16
May 28, 2006 11:12 PM
Mike17
Feb 11, 2004 02:31 PM
