Replacing front lower ball joint
Old Feb 21, 2007 | 07:21 PM
joker4096's Avatar
Default Replacing front lower ball joint
Hi guys, i need help replacing both front lower ball joints on my 89 crx. these are the ones that hold the lca to the knuckle. anyone know how to do this? i know i need a ball joint installer/remover tool. where can i get one?
Old Feb 21, 2007 | 07:26 PM
boostedblkef's Avatar
Default Re: Replacing front lower ball joint (joker4096)
the best way is to use a press just take it to a shop its a 15 min job
Old Feb 21, 2007 | 09:41 PM
joker4096's Avatar
Default Re: Replacing front lower ball joint (boostedblkef)
so i have to take the whole crx knckle to them?
Old Feb 21, 2007 | 09:43 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joker4096 &raquo;</TD></TR><TR><TD CLASS="quote">so i have to take the whole crx knckle to them?</TD></TR></TABLE> If you use the press, yes. Autozone does rent out a little ball joint press to use though for the D.I.Y. Job.
Old Feb 21, 2007 | 09:51 PM
mra4886's Avatar
Default Re: Replacing front lower ball joint (dr_latino999)
well idk if this is the smartest way but it wroked for me. i just seperated the lower ball joint from lca by prying on it and it comes out of the lca then i pulled the old ball joint boot off cause it wasnt going to be reused then i hammered on the ball joint so it would pop out then pushed my new one in and i was done. very easy DIY. gl
Old Feb 21, 2007 | 09:52 PM
joker4096's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> If you use the press, yes. Autozone does rent out a little ball joint press to use though for the D.I.Y. Job.</TD></TR></TABLE>
yea i might use that to do it myself since my crx is not running to take it to a shop. shouldnt be too difficult anyway. Just looking for a little walkthrough.
Old Feb 24, 2007 | 07:17 PM
BigChuck's Avatar
I got a c-clamp rental with 23 cups, and a fews jaw pullers but still can not get the Ball joint off.
The stud is too loose. I think I will take out the knockle tomorrow in the light and beat the crap out of them.
I put the new BJs in the freezer,
Should i lube the joints and control arms?
Any tips or tricks??
thanks
Old Feb 24, 2007 | 10:43 PM
Crx Jimmy's Avatar
Default Re: Replacing front lower ball joint (BigChuck)
I just beat them with a nice mallet, a couple hits and they come out. clean up where it came out then put the new one in and put a piece of wood(so you dont damage your new ball joint) on top and hammer it back in.
Old Feb 25, 2007 | 12:30 AM
4thgenhtch's Avatar
Default Re: Replacing front lower ball joint (Crx Jimmy)
Dont forget to pull the c-clip off that holds them in
Old Feb 25, 2007 | 12:48 AM
nexgen91's Avatar
Default Re: Replacing front lower ball joint (4thgenhtch)
i just beat the sh*t out of them with a hammer until they came out, and did the same to put them back in. i tried to not dent the top to much, i didnt think about using a piece of wood.
Old Feb 25, 2007 | 07:14 AM
BigChuck's Avatar
Default Re: Replacing front lower ball joint (nexgen91)
Well got good news. I took the knockle off and beat it out. And got the news frozen one in, I just need to do the other side.
Thanks
Old Feb 25, 2007 | 07:56 AM
philkehn's Avatar
I just did mine a couple days ago
Take your entire hub assembly out of the car of course, just remove the c'clip i used a flat head and a knife. after that i put the top part of the hub up against a wall and beat it out, i popped out in about 3 hits. I just used a vice and a couple peices of pipe to push the new ones. I used the pipes in a similar way to the balljoint installer remover, its actually easy :thumpup:
mikekc99
Jun 13, 2007 10:42 PM
innes887
Apr 12, 2007 04:03 PM
rasinhell
32
Jan 17, 2005 04:57 PM
STG3PWR
12
Jun 5, 2004 06:39 PM
87_accord_lx
Jun 22, 2003 08:44 AM
