air conditioning problem
Always check your fuses first, in the car and under the hood. Check to see if your air conditioning fan is running when you switch on the a/c. It sounds like the fan is not on, so when you start driving and the air goes over the condenser it is cooling it for you instead of the fan.
Good luck
Good luck
DaveSi677
12
Dec 10, 2008 06:36 AM
