help > is a spun rod the end of things ?
Old Feb 21, 2007 | 02:45 PM
b18c1delly's Avatar
Default help > is a spun rod the end of things ?
have a loud knocking sound coming from the lower end of the block >
my mechanic says either a bad oil pump or worst > a spun rod >
is this the end of my gsr ?
Old Feb 21, 2007 | 03:15 PM
NJIN BUILDR's Avatar
Default Re: help > is a spun rod the end of things ? (b18c1delly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1delly &raquo;</TD></TR><TR><TD CLASS="quote">have a loud knocking sound coming from the lower end of the block &gt;
my mechanic says either a bad oil pump or worst &gt; a spun rod &gt;
is this the end of my gsr ? </TD></TR></TABLE>
Actually it's just the beginning.Welcome to the world of engine swap/rebuilding.
Old Feb 21, 2007 | 04:03 PM
b18c1delly's Avatar
Default Re: help > is a spun rod the end of things ? (NJIN BUILDR)
no money for another SWAP &gt; but i could probably suck up a rebuild &gt;
any idea what this may run about ?
Old Feb 21, 2007 | 04:06 PM
Crazydave's Avatar
depends on what needs to be done.
I spent $1000 on my bottom end including assembly
I then spend $400 on the head to get that redone too.
plus I got new headgasket, hoses, waterpump, timing belt, valvecover gasket, etc...
Old Feb 21, 2007 | 06:04 PM
FIGARILA's Avatar
if the crank is damaged you might as well get t a new one...and thoroughly clean everything to make sure you don't have shavings clogged anywhere. it really depends on how bad the damage is. A swap might actually be cheaper.
Old Feb 22, 2007 | 04:01 AM
b18c1delly's Avatar
Default Re: help > is a spun rod the end of things ? (Crazydave)
did everything had to be absolutely OEM &gt; have you pass CA/BAR smog yet &gt;
worried that with all the engine work that it may create CA smog issues
jjohn6438
Honda Civic (2001 - 2005)
Dec 6, 2006 10:34 AM
CA6VTEC
May 20, 2004 05:07 PM
Rocket
Dec 5, 2003 03:44 PM
satan_srv
Jan 3, 2003 10:36 AM
