What would cause wheel jerk while braking and shifting?
Old Feb 21, 2007 | 12:30 PM
WhiteOnRice's Avatar
Default What would cause wheel jerk while braking and shifting?
I just replaced all struts with KYB GR2s and when I brake or let off the gas my wheel jerks to the left maybe about an inch.
Thanks
Old Feb 22, 2007 | 03:06 PM
Bump
Old Feb 22, 2007 | 07:05 PM
HONDA300's Avatar
look at the tie rod ends the nut could be loose or the could just be bad.
Old Feb 22, 2007 | 07:14 PM
They weren't touched during the strut install and the problem is so profound that it's obvious something happened during install. Could it just need an alignment?
Old Feb 22, 2007 | 07:34 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: What would cause wheel jerk while braking and shifting? (fizix_skate)
did u tighten with the car on the ground or put load on the lower control arm?
Old Feb 26, 2007 | 07:36 PM
Tighten ball joints you mean? Yes I put a load (jack underneath) on them.
Old Feb 27, 2007 | 01:37 AM
92ehatch's Avatar
Default Re: (fizix_skate)
does it do it on every road? or just one one shitty one you drive alll the time?
could be alignment, if you havent gotten it aligned yet.
Old Feb 28, 2007 | 05:50 PM
Every road, yeah. I'll get an alignment... before I sell it.
Old Feb 28, 2007 | 05:53 PM
EM1_00Si's Avatar
Alignment/tires would be my first guess
Corksil
10
Sep 13, 2009 05:00 PM
prelude_93vtec
Sep 11, 2009 10:18 AM
ke98248
Oct 23, 2007 12:10 PM
beav
Suspension & Brakes
Jun 15, 2007 05:47 PM
jdmeg9
Jan 8, 2005 03:38 PM
