Rota Slipstreams... 15x6.5 +40 offset, any problems?
Old May 20, 2002 | 06:16 PM
Driven's Avatar
Default Rota Slipstreams... 15x6.5 +40 offset, any problems?
anyone have a set of these rims? Do they fit 205s without a problem? +40mm offset a problem? Do they stick out closer to the fender, or they closer to the spindle (keep forgeting offsets and how they work).
Basically, i want to put 205/50r15s V700 Victoracers on a set of 15" rims that are light and cheap. The cheapest and lightest rim is the Rota Circuit 8s (at $125/ea)... but they are god awful ugly... the Slipstreams are ugly, but not AS ugly...I have the 4 piston brakes to clear and I really hate to have to buy spacers as well...
So, any info is greatly appreciated.
Old May 20, 2002 | 06:19 PM
allmotorEG-SI's Avatar
Default Re: Rota Slipstreams... 15x6.5 +40 offset, any problems? (Driven)
the Slipstreams are ugly, ...
Bite your tounge! those rims are bad ***! but i've been wondering the same thing myslelf.
Old May 20, 2002 | 06:53 PM
dmotoguy's Avatar
Default Re: Rota Slipstreams... 15x6.5 +40 offset, any problems? (CAMAROCRUSHER)
i am in love with the slipstreams (spoon replica)
Old May 20, 2002 | 07:00 PM
Denny317's Avatar
Back to the topic....the slipstreams will fit the car without any problems. I had 205/50 tires and no rubbing at all. Lowered ~2 inches. HTH.
Old May 20, 2002 | 08:39 PM
wickedxboi's Avatar
Default Re: Rota Slipstreams... 15x6.5 +40 offset, any problems? (Denny317)
u should have no problems with rubbing on 205's
Old May 20, 2002 | 09:08 PM
Steve91's Avatar
I just installed Slipstreams with 205 Azenis last week. They clear the brake caliper by a mile and the fit is great. They don't rub, but I have very stiff suspension.
Old May 20, 2002 | 09:25 PM
Driven's Avatar
Default Re: Rota Slipstreams... 15x6.5 +40 offset, any problems? (Steve91)
i just utilized the search function... and it worked!!!
About the brake caliper clearance... thing is, i have the 11" brake rotors with 4 piston wilwoods... do you have the same? I'm sure it'll fit (hopefully) without any spacers...
Old May 20, 2002 | 09:27 PM
Steve91's Avatar
I thing the Fastbrakes will clear. Isn't the picture on their web page of a Rota Circuit * in 15"?
I run the stock rotors and there is tons on clearance
Old May 21, 2002 | 06:35 AM
keithv's Avatar
for a good article on offset, check this tirerack page:
http://www.tirerack.com/wheels/tech/offset.htm
so the greater the + offset, the further they are away from the spindle...
NA-Cutie
Aug 25, 2004 10:37 PM
Driven
May 21, 2002 07:46 AM
