Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Temp gauge overheating while breaking
Old Feb 21, 2007 | 11:30 AM
redacura's Avatar
Default Temp gauge overheating while breaking
I have a 97 cl 3.0 and my temp. gauge in the cluster is at normal, in the middle while i'm driving, but when I come to a stop, the temp slowing starting getting hotter until it reaches the the hot line. Then when I drive off it lowers. Any ideas?
Termistat?
Old Feb 21, 2007 | 12:04 PM
DaiJekBok's Avatar
Default Re: Temp gauge overheating while breaking (redacura)
Check the coolant level in both the radiator and the overflow container when the engine is cool.
Check that the cooling fan comes on when the car is fully warmed up. If it doesn't, it could be the fan switch or the fan itself. You can apply 12V DC to the fan directly to rule the fan out.
It may also be the thermostat. When they fail they tend to fail in the open position -- this allows the water to circulate through the block too quickly such that it doesn't have enough time to absorb heat from the engine and therefore diminishes the heat exchanging effect.
I'd get it checked out before driving much more -- the more time it spends overheating the more likely you are to cause some serious [read: expensive] damage.
Old Feb 22, 2007 | 06:34 PM
Kenso's Avatar
HT White Ops
Check the fans as mentioned above, it's not uncommon to see them fail on CL's from that era. Definitely don't keep driving it with this problem.
Shidou
Sep 16, 2016 06:49 AM
aasaa666
May 31, 2010 07:15 AM
madcivic31
Jan 29, 2010 09:23 AM
walrus_07
Feb 21, 2009 10:16 PM
