flat vs dish valves
Old Feb 21, 2007 | 11:12 AM
ge_itr's Avatar
Default flat vs dish valves
what are the differences?
Old Feb 21, 2007 | 11:21 AM
Chuckles99SH's Avatar
Default Re: flat vs dish valves (ge_itr)
a slight compression bump, I forgot the actual value but it was minimal. I would be concerned about the flat valves weight adding to the valve train, that would probably be minimal also though.
Old Feb 21, 2007 | 11:37 AM
98vtec's Avatar
moderator emeritus
Default Re: flat vs dish valves (Chuckles99SH)
the face of the valves are flat causing a slight increase in compression. The stock valves are concave.
Some argue that the little compression you gain is only taken away by the added weight of the valve to make the face flat.
pretty common sense if you put a little THOUGHT to it.
Old Feb 21, 2007 | 11:46 AM
92hondalude's Avatar
Default Re: flat vs dish valves (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">the face of the valves are flat causing a slight increase in compression. The stock valves are concave.
i would say the compression bump is better then the weight.... what do you think 98vtec?
Old Feb 21, 2007 | 11:49 AM
98vtec's Avatar
moderator emeritus
Default Re: flat vs dish valves (92hondalude)
i dont know the differences in weight so i couldnt tell yuh. I plan on using regular valves in my motor. My compression is being worked on by the crank, pistons and head gasket/or head mill. Honestly rather have light valvetrain than a minute bump in compression.
this is all just my own speculation tho.
Old Feb 21, 2007 | 11:50 AM
Mykizism's Avatar
very marginal if any.. if anything if was NA i would get flat top valved.. i went with dished bc i wanted lower compression
Old Feb 21, 2007 | 12:12 PM
vinuneuro's Avatar
Default Re: flat vs dish valves (Mykizism)
Good advice on flat valves:
https://honda-tech.com/zerothre...08720
Old Feb 21, 2007 | 12:14 PM
ge_itr's Avatar
but if your going NA, wouldn't you want it to be light also? i have 12.0:1 cr pistons already, which one would benefit more?
Old Feb 21, 2007 | 12:17 PM
98vtec's Avatar
moderator emeritus
why do you need any higher compression than 12:1?
Old Feb 21, 2007 | 12:48 PM
Missing Gears's Avatar
flat valves dont flow as well as stock/concave valves. stick w/ stock valves
Old Feb 21, 2007 | 02:16 PM
PrecisionH23a's Avatar
flat NA
dish TURBO
Old Feb 21, 2007 | 02:54 PM
Default Re: flat vs dish valves (PrecisionH23a)
just going from what ferrea has told me:
the small bump in compression from the flat valves will not make up for the hp loss from the valves not flowing and pulling in as much air as a regular valve. they had just done some flow testing before i spoke w/ them. this was a few years ago.
ferrea offers both styles and they recommended their regular/concaved valve for my n/a application. they make a great product, but its hard to beat a stock valve for a mild application.
Old Feb 21, 2007 | 04:05 PM
Default Re: flat vs dish valves (Missing Gears)
if that was the case why would they make flat valves?
Old Feb 21, 2007 | 05:04 PM
just another option to offer people who are looking for something to spend their $$ on.
Old Feb 22, 2007 | 07:24 AM
Lubo_25's Avatar
on a supertech valve the difference is around 2-3 grams or so approx...i have the dish faced ones they weigh about 48 grams...(approx numbers)
Old Feb 22, 2007 | 10:08 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Missing Gears &raquo;</TD></TR><TR><TD CLASS="quote">flat valves dont flow as well as stock/concave valves. stick w/ stock valves </TD></TR></TABLE>
the concavity of the stock valves creates a low pressure pocket, pulling the intake charge over the edge of the valve....ps stock valves are very well designed, just get a new set of those and you'll be set.
flat vales cause no such effect
Old Feb 22, 2007 | 12:10 PM
Buffalo's Avatar
Default Re: flat vs dish valves (mgags7)
1st of all o'm not mechanic but i believe that my mind anderstunts physics verry good.
a. The way i see it with flat valves your motor makes more compression but are also hevyer. That means that if your valve springs are made to pull the stock valves to cutch up with the stock rev speed they will not be able to pull the hevyer valves with the same speed to prevent valve to piston contact.
b. I know that about 95% of the ppl that replce thier valves also replace the springs+retainers but as simple as my exsample above most of those ppl replace the spring+retainer package to be able to rev higher but again, with the hevyer valves, you will not be able to rev as high as the aftermarket spring made for.
c. There ARE some companys that offer ti flat valves wich are lighter than the oem dish type ones but they cost too much to worth it and you can make more power ,than the little compression upgrade, spending the extra money on other parts.
Once again, i'm not a mechanic, this is just the way i thing of it so if i'm wrong please correct me. We all have something more to learn.
p.s. my english are not so good, i know.
Old Feb 22, 2007 | 01:28 PM
UK_Luder's Avatar
Default Re: flat vs dish valves (Buffalo)
Skunk2 offer two types of valve, standard and high compression. The high compression ones still have a dish in the face, but not as big a dish as the standard ones (I've checked). They supposedly increase compression by about .3 - .4
https://honda-tech.com/zerothread?id=1542387
Old Feb 22, 2007 | 04:42 PM
Default Re: flat vs dish valves (UK_Luder)
i had some skunk flat valves, they are not concave. they only have a flat round spot in the center.
not only that, but they are alot weaker than stock valves. i would never recommend buying a set. if you want aftermarket valves for some reason, go w/ ferrea.
kelvinchau25
Aug 9, 2006 10:11 AM
Project-D
Aug 6, 2006 09:03 AM
NeVeR bLoWn
Oct 20, 2003 02:29 PM
mr. wu
Jun 28, 2003 12:57 AM
h46it
Jun 2, 2002 09:36 PM
