Anyone done GSR cluster/dash into CRX ?
Old May 20, 2002 | 06:11 PM
dustin's Avatar
Default Anyone done GSR cluster/dash into CRX ?
I just picked up a gen 3 gsr cluster/dash/center console for my crx (thanks jason!)
I know I can just repin the cluster wires to use it... but anyone have any tips or suggestions on fitting the entire dash in ?
Old May 20, 2002 | 08:12 PM
QWKPHKR's Avatar
Default Re: Anyone done GSR cluster/dash into CRX ? (dustin)
i did the complete swap into my CRX with a 01 ITR dash (everything) and I would suggest not doing it. Not because I dont like it ( I LOVE IT) but it is such a pain in the *** to get that thing to fit in, along with custom brackets, and some bitch *** wiring to get everything to work including the speedo (from mech. to elec.) I moved the ignition to perfectly position the dash in the center of the car. If you really wanna do it I would be more than willing to help... but i'm just warning you before you get into something you might not finish..
Pete
Old May 20, 2002 | 08:13 PM
dustin's Avatar
Default Re: Anyone done GSR cluster/dash into CRX ? (QWKPHKR)
Oh, I'll finish. The car is completely stripped and I have all the time in the world.
I'd love any suggestions you have. I have some fabrication equipment (tig welder, band saw, etc). I have the underdash wiring harness and the VSS.
Old May 20, 2002 | 08:35 PM
89 CRX SI's Avatar
man that is going to look shhwweeeeet.
Old May 21, 2002 | 12:19 AM
ImportHatch's Avatar
Default Re: Anyone done GSR cluster/dash into CRX ? (89 CRX SI)
Post up some pics, I wanna see, and how did you change the speedo from cable to electronic????
Yager-
Old May 21, 2002 | 04:29 AM
cyberx's Avatar
Default Re: Anyone done GSR cluster/dash into CRX ? (ImportHatch)
how much would it run to do it professionally?? incase i didnt want to screw anything up......? i want to see pics, because my friend has a 2000 ITR and i love his interior... would love to see it in a CRX!! what about just the center part with the hand rest....
Old May 21, 2002 | 05:42 AM
SuperCivic's Avatar
you get the electronic vss out of a tranny, take the cable vss out of your tranny, put the electronic vss in your tranny, then wire it up..power, ground, and VSS pulse.
Old May 21, 2002 | 08:50 AM
LSBeast's Avatar
Can I see some pics of everyone's dashes.
Old May 21, 2002 | 09:02 AM
marty's Avatar
Default Re: Anyone done GSR cluster/dash into CRX ? (neo0024)
dustin. as far as i was concerned, the dash/bezel cover didnt need cutting but you did have to fabricate brackets to make the cluster sit the way you do. as far as the wiring goes if you need i can get it for you.
marty
Old May 21, 2002 | 09:03 AM
marty's Avatar
whoaaa... i just read dash.. thats outta my league.
Old May 21, 2002 | 09:18 AM
dustin's Avatar
Default Re: Anyone done GSR cluster/dash into CRX ? (MugenEF7)
I do need the wiring info for the dash too... I don't have the helm manual for the CRX, only the integra.
Old May 21, 2002 | 09:21 AM
marty's Avatar
you need wiring info from the CRX and the Integra to try to piece together what goes with what. But the tricky part is the electro speedo sensor (cluster). Someone figured out how to do it, but I personally dont.
Old May 21, 2002 | 09:27 AM
dustin's Avatar
I already know how to do the VSS.
I have the CRX and Integra under dash harnesses already I just need the pin outs for the CRX cluster...
Old May 21, 2002 | 09:35 AM
crux131's Avatar
There is a link to a PDF formatt Helms manual in this thread...https://honda-tech.com/zerothread?id=186149 ...you can look up the info you need here hopefully.
Old May 21, 2002 | 09:58 AM
Renegade's Avatar
Default Re: Anyone done GSR cluster/dash into CRX ? (crux131)
I'd like to see a pic of one...
SuperCivic's Avatar
http://b16a.honda-perf.org/cluster.html has the chart i used to wire in my SiR cluster..there are a few differences but you should be able to figure them out. that chart should give you the CRX info you'll need..you can also look at the back of your crx cluster and trace each individual pin to the light/function it does..then look at the teg cluster and figure out where everything goes
[Modified by SuperCivic, 6:59 PM 5/21/2002]
Old May 21, 2002 | 01:01 PM
FUP23's Avatar
New User
Default Re: Anyone done GSR cluster/dash into CRX ? (SuperCivic)
Ive seen one picture of it, it looks so awsome. post em up
Old May 23, 2002 | 11:52 AM
dustin's Avatar
Default Re: Anyone done GSR cluster/dash into CRX ? (Devin17)
Any other ideas?
Old May 23, 2002 | 02:43 PM
mackymcg's Avatar
Here is an ITR cluster in a hatch:
Old May 23, 2002 | 02:49 PM
Renegade's Avatar
Default Re: Anyone done GSR cluster/dash into CRX ? (mackymcg)
nice
Will have to look into getting one..
Old May 27, 2002 | 06:52 PM
cyberx's Avatar
Default Re: Anyone done GSR cluster/dash into CRX ? (98401R)
im getting a 97 ITR dash with everything all the wires behind it and everything, and handrest for 350$ also im getting it from Canada, so it has Kilometers..... 17,000 Kilometers on the gauges.........., PLEASE I NEED ALL INFO for installing it in my 90 CRX!!!!!!!!!!!!!!!!!!!!!!!! i want to have a totally diff crx then anyone in my state....... please email me with info as well CarRacingXtreme@aol.com send as much pics as possible
Old May 27, 2002 | 09:28 PM
Jaker's Avatar
Hey MackyMCG,
Could you post up another picture of your ITR cluster setup with more light, so there is a little more detail in the corners by the fuel and temperature gauges? Also, which cluster cover did you use, the 88-89 or 90-91?
Old May 27, 2002 | 10:51 PM
91civ's Avatar
Default Re: Anyone done GSR cluster/dash into CRX ? (Jaker)
I would like to know this also...which cluster cover did u use, and what brackets did u use to mount the cluster to the dash?
ttt
BSeriesRescueteam
May 7, 2009 10:29 AM
dem0nk1d
Jul 12, 2007 05:49 AM
funkified
25
Nov 30, 2006 09:08 PM
RA122324
Jun 6, 2005 01:04 PM
91hatcheezy
Sep 18, 2002 04:54 AM
