Help - drivers side window on 1995 Accord EX
Old Feb 21, 2007 | 05:50 AM
Keedo98's Avatar
Default Help - drivers side window on 1995 Accord EX
Hello - I need some problem solving from the experts!!! I have a 95 Accord EX, 4 door. The drivers side front window will not work - the other 3 do. When I try and put the window down, I can sense that their is juice there because the lights dim a little but the window will not go up or down.
Do you think it is a fuse, regulartor/motor or switch?? I am kind of handy so if it is a motor/regulator is this something that is easy to fix?
Thx for your help (first time poster!!)
Keedo98
Old Feb 21, 2007 | 06:07 AM
The-Kid's Avatar
Hmmmm............ do you hear the motor at least whinning?
I would say this, check the fuse first. If the fuse is good, i would take out the window motor regulator assembly and grease/lubricate that thing.
Try again, and if it still doesn't work, you might need a new assembly?
BTW clean ur window tracks and grease them with silicone spray.
Old Feb 21, 2007 | 07:14 AM
Keedo98's Avatar
Default Re: (The-Kid)
<U>Hmmmm............ do you hear the motor at least whinning? </U>
Nope - makes no noise at all.
Thx for the input! Just out of curiosity, if I have to replace the motor/regulator, is that somehting one person can do? I would hate to take the door paneling off and get my self in a pickle.
Thx Again!
Old Feb 21, 2007 | 08:00 AM
Tuner's Avatar
Hey man its the window motor!! I have a 1995 honda Accord 2D EX. and the same crap happen to me!! And i had to change the motor out on it!!! So yeah man it definately the motor!!
Old Feb 21, 2007 | 10:32 AM
Twixle's Avatar
ate my pixel
Default Re: (Tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tuner &raquo;</TD></TR><TR><TD CLASS="quote">Hey man its the window motor!! I have a 1995 honda Accord 2D EX. and the same crap happen to me!! And i had to change the motor out on it!!! So yeah man it definately the motor!!</TD></TR></TABLE>
No, it's not definitely the motor. It's either the motor, or you have a bad control switch for your power windows. Take out the switch and make sure it's clean before you go to the work of replacing the window motor and regulator.
I replaced my window motor to no avail, it ended up being a bad switch. So I have an extra driver's side motor and regulator if you want it.
As far as replacing the motor and regulator, you can do it yourself no problem, I did. The only thing to be careful with is when you unbolt the regulator make sure you have ahold of the window. I just pulled the window out, replaced the motor and regulator, and then stuck the window back in and bolted the regulator on. Took maybe an hour.
Old Feb 21, 2007 | 02:18 PM
Keedo98's Avatar
Default Re: (accord2021)
Thank you for you input!!
I will check out the switch and then go from there
Have a good one!!!
Great Forum!!!
Terabass
Jul 1, 2008 12:41 PM
slim689
Feb 14, 2007 03:21 PM
mark_is_gay
Sep 17, 2006 06:02 PM
acketon
Jul 2, 2006 11:01 PM
JDMNICA
Audio / Security / Video
Aug 25, 2005 06:42 PM
