Cam gears not lining up... need help!!!
Old Feb 20, 2007 | 09:34 PM
realis9's Avatar
Default Cam gears not lining up... need help!!!
I was tensioning my timing belt and noticed the cam gears do not line up. I used the coat hanger trick to tension the timing belt because I didn't have a spring. When the crank pulley is at TDC, the cam gears do not line up. Is this normal? Does this interfere with the timing? What should I do? Any help is greatly appreciated.
Modified by realis9 at 12:33 AM 2/21/2007
Old Feb 20, 2007 | 10:26 PM
Circuit Star-29's Avatar
Default Re: Cam gears not lining up... need help!!! (realis9)
Pic isn't working. Ill assume you have stock gears.
Set Crank to TDC, Remove the timing belt and reset the cams. If you have adjustable gears reset them to 0 degree. Torque the tensioner to 33 ft lbs.
If you need a manual lmk.
Old Feb 20, 2007 | 11:37 PM
BoBo Racing's Avatar
Default Re: Cam gears not lining up... need help!!! (Circuit Star-29)
Old Feb 20, 2007 | 11:51 PM
realis9's Avatar
it's BDL cam gears. I don't know why the pic is not working.
Old Feb 21, 2007 | 12:02 AM
iheartintegras's Avatar
Fixed
Old Feb 21, 2007 | 03:10 AM
RedR's Avatar
Default Re: (iheartintegras)
milled head? thicker hg?
Do u have any of these?
With my thicker hg i had to use adjustable camgears.
Old Feb 21, 2007 | 03:58 AM
Teamdiesel's Avatar
bump, because I want to know this also
Old Feb 21, 2007 | 04:09 AM
D's Avatar
D
You don't have a problem.
Old Feb 21, 2007 | 04:16 AM
Willard's Avatar
Default Re: Cam gears not lining up... need help!!! (D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote">You don't have a problem.</TD></TR></TABLE>
Toss the belt on and see if that helps.
Old Feb 21, 2007 | 04:25 AM
realis9's Avatar
Default Re: Cam gears not lining up... need help!!! (Willard)
stock head gasket and stock head. No milling. Is that normal?
Old Feb 21, 2007 | 05:11 AM
D's Avatar
D
If you really are concerned... Remove the crank pully, and use the TDC indicator Cast into the oil pump housing (which is dowel pinned to the block), the crankshaft timing belt drive gear also has a corresponding TDC mark. The lower timing belt cover is, well... not as accurate as you believe it to be.
I guess i'll repeat myself... you don't have a problem.
Old Feb 21, 2007 | 06:12 AM
realis9's Avatar
cool. I just wanted to know if it is normal and if it is going to affect my timing. I plan to do a valve adjustment, but i was concerned.
crxaddikt
Jun 4, 2012 12:18 PM
realis9
28
Feb 22, 2007 07:10 PM
redlseg
Apr 20, 2005 07:07 PM
Muckman
Sep 22, 2004 09:44 AM
