b16 with stock si distributor..timing issues.
I bought this car and it was already using the stock si dist. I can't get the timing past 18 degrees. Is this because of not having the b16 dist? The timing mark is the long line in front of (radiator side) the motor mount on the black timing belt cover correct? The one mark out by itself is 16 degree and the one in the middle in the group of three is 0, right? Sorry for my ignorance but I'm new to the B series engines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13g-crx »</TD></TR><TR><TD CLASS="quote">I bought this car and it was already using the stock si dist. I can't get the timing past 18 degrees. Is this because of not having the b16 dist? The timing mark is the long line in front of (radiator side) the motor mount on the black timing belt cover correct? The one mark out by itself is 16 degree and the one in the middle in the group of three is 0, right? Sorry for my ignorance but I'm new to the B series engines.</TD></TR></TABLE>
No you want the one in the middle ,the lone on is zero
I dont understand, but either or, plug the light onto #1 shine it at teh crank, look for the middle line to line up with the pointer on the cover, move dissy accordingly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist »</TD></TR><TR><TD CLASS="quote">I dont understand, but either or, plug the light onto #1 shine it at teh crank, look for the middle line to line up with the pointer on the cover, move dissy accordingly</TD></TR></TABLE>
OK, but with the timing light set at 0 degree's, right? 16 degrees I should be on the one by itself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oodie »</TD></TR><TR><TD CLASS="quote">You need a b16 distributor</TD></TR></TABLE>
So I've gathered
.... but the car has been running fine untill a couple of days ago. I'm going to make sure I'm not a tooth off on the intake cam tomorrow.
So I've gathered
dr_latino999
Dec 2, 2004 09:55 PM
