milkshake head
Old Feb 20, 2007 | 07:15 PM
kinoukiita's Avatar
Default milkshake head
waterpump-_- antifreeze or corosion resdue located around the alternator and water pump area
shakey engine
milky head sad and disasterous
overheating was the first problem
I just want a photo diy or anything that I can use to step by step this repair...
Old Feb 20, 2007 | 07:29 PM
dr_latino999's Avatar
Default Re: milkshake head (kinoukiita)
Was that supposed to be a poem? So what do you need instructions on?
Old Feb 20, 2007 | 07:49 PM
kinoukiita's Avatar
Default Re: milkshake head (dr_latino999)
instructions on removing the things i may need to replace or repair like the head the waterpump- n e thing like that- i got the book but anitfreeze blew up on it- long story...
this was the whole deal man- I was driving to pick up 1 fat five as my spare and my car started overheating- the freakin radiator resivor started looking ugly so i thought flush my radiator- so i did- then all of a sudden took it for a test drive and it started blowing out grey smoke out my tailpipe- sumtins up with my water pump or sumtin under the tb cause gunk and build up keeps on showin up there i cant find the leak if any... then im starting to remove the cam gear cover and all that(im not really sure how to start the water pump replacement) with the head and i see the milk shake- so im thinkin blown head gasket...
i think you would rather read my poem than this story hahaha
Old Feb 20, 2007 | 07:51 PM
ekslax's Avatar
71.172.180.139
i also thought it was a really bad haiku or something
Old Feb 22, 2007 | 07:20 AM
~sp33~'s Avatar
EFB055
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Was that supposed to be a poem? So what do you need instructions on?</TD></TR></TABLE>
LMAO!!!!!!!!!!!!
Old Feb 22, 2007 | 07:44 AM
MagnaniEG6's Avatar
Default Re: milkshake head (~sp33~)
More like a Haiku
Old Feb 22, 2007 | 09:15 AM
wiZCo's Avatar
Stouts 'n' Scotch
If your oil is milky colored you need a new headgasket dude.
Old Feb 22, 2007 | 09:30 AM
salman's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">If your oil is milky colored you need a new headgasket dude.</TD></TR></TABLE>
Old Feb 22, 2007 | 09:54 AM
Tippyman's Avatar
Default Re: (salman)
Or new sleeves!
Old Feb 22, 2007 | 10:08 AM
Loserkidwac's Avatar
Default Re: (Tippyman)
You need to go buy/download a manual for your car...
Old Feb 22, 2007 | 10:26 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
Or new sleeves! </TD></TR></TABLE>
Worst case scenario, but not out of the question. If he had overheating and rough idle problems, I'd start with the headgasket. Although it sounds like he screwed it up even further by having it overheat repeatedly.
Old Feb 22, 2007 | 10:41 AM
Rex-Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kinoukiita &raquo;</TD></TR><TR><TD CLASS="quote">......... I was driving ......... and my car started overheating- the freakin radiator resivor started looking ugly .......... and it started blowing out grey smoke out my tailpipe........... then im starting to remove the cam gear cover and all that with the head and i see the milk shake- so im thinkin blown head gasket..........</TD></TR></TABLE>
Ok , now it makes more sense , short and to the point !
You got yourself a blown head gasket , key words in this is grey smoke and milky oil........ I found this TSB from Honda updating the torqe specs , this replaces the sequence and specs in the manual. http://www.hondaworkshop.com/misc/97-047TSB.jpg
Get another helms manual but use these updated specs from honda.
Dont forget to replace your timing belt and water pump while your in there , better to do this now why you have it apart.
Hope this helps,
Peace.
Old Feb 22, 2007 | 10:45 AM
Default Re: milkshake head (Rex-Si)
I'd also suggest replacing thermostat and rad cap...since they could be causes to a blown headgasket and arn't to expensive to replace....
Old Feb 22, 2007 | 10:47 AM
danmdevries's Avatar
Default Re: milkshake head (Loserkidwac)
If you overheated, chances are you may have a warped deck/head....
Old Feb 22, 2007 | 01:16 PM
GarageAlchemist
Guest
Posts: n/a
Default Re: milkshake head (danmdevries)
your head gasket is bad.. and dood.. wtf was that post lol
Old Feb 22, 2007 | 08:19 PM
kinoukiita's Avatar
I am an artist so it works out in the end- thnx to all haha the heads off the block now and all I need to do is buy the replacement parts- I didn't know exactly what to get but now I do
Thanks
Old Feb 22, 2007 | 11:23 PM
hates hondatech's Avatar
* B A N N E D *
lol @ poem.
hondamike89
Feb 28, 2009 01:40 PM
ronqqq
Oct 24, 2006 08:59 PM
barkwaffle
Jun 15, 2005 01:52 PM
jweller
Sep 25, 2003 04:27 AM
jason_thaomoto
Jun 5, 2003 11:26 AM
