Can you turbo charge a K24 accord?
I have an 07 Accord Coupe 2.4 and I'm thinking about a turbocharger.
I found a few postings with a some options:
https://honda-tech.com/zero...73346
http://www.importperformancepa....html
Anyone have any recommendations or suggestions to point me in the right direction? Or if you know of any other kits out there?
Thanks
Mike
Thanks
Mike
Not yet. There is a company here in Lexington Ky that has a kit for the '03-05 but it appears that the throttle by wire computer system will put a hold on the newer cars for a while. Maybe Hondata will get involved soon.
I heard from someone that installing a turbo on an engine with a high compression ratio could potentially blow the engine. Would I have a problem with installing a turbo on my car? Are there any other mods I can do to strengthen the engine so that it could handle a turbo? Or would a supercharger be the more ideal way to go?
build the bottom end with forged pistons and rods and you should have no issues with blowing motors. boosting a stock motor is running on borrowed time, eventually something will fail, most likely a piston ringland.
you may have problems finding any engine management for it however, aside from a piggyback like the e-manage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB »</TD></TR><TR><TD CLASS="quote">
you may have problems finding any engine management for it however, aside from a piggyback like the e-manage.</TD></TR></TABLE>
I just saw something the other night where a guy was running a boosted element off of a RSX-S ecu with Hondata. There was some conjecture that an accord could be run the same way since the elements k24 is close to the accords.
here it is
http://www.elementownersclub.c...31219
I'd rock a boosted element
here it is
I guess its theoretical that you could boost a k24a8 if you swapped the TB with a k24a4. I myself have my car being built (done in less than two weeks I hope) and a 5spd swap on a stock motor. There have been people that have ran 30psi on the k24 bottom end in civic hatches for awhile before blowing them. 10-11psi is the general consensus on a k-series block as far as safe boost level. I myself am only looking for 7psi before I get more money to open up the head and block. I'm using a custom harness piggybacked through a 02-04 RSX PRB ECU and kpro.
verzatile34
Oct 4, 2003 10:10 AM
