valve adjustment
Old Feb 20, 2007 | 07:00 PM
00preludeh22a's Avatar
Default valve adjustment
is there a special tool that i need to do a valve adjustment, if not what can i use?
Old Feb 20, 2007 | 07:03 PM
nonvteclude's Avatar
Default Re: valve adjustment (00preludeh22a)
the only special tool you will need is the valve lash feeler gauge other than that just a flat tip screw driver and a socket wrench
Old Feb 20, 2007 | 07:11 PM
98vtec's Avatar
moderator emeritus
Default Re: valve adjustment (nonvteclude)
i bought my valve lash tool on ebay for 23 dollars. Makes adjustments go so much faster.
Old Feb 20, 2007 | 07:14 PM
92hondalude's Avatar
Default Re: valve adjustment (98vtec)
i made mine.
only $15 using expensive ace tools lol
Modified by 92hondalude at 11:29 PM 2/20/2007
Modified by 92hondalude at 11:30 PM 2/20/2007
Modified by 92hondalude at 11:31 PM 2/20/2007
Old Feb 20, 2007 | 07:18 PM
i have aleady tried that. the valves sit too far down in the head. any suggestions
Old Feb 20, 2007 | 07:45 PM
CGags13's Avatar
either buy the tool or make it like 92hondalude did...i like that idea there man..cheap solution..to shelling out 70 bones at the Snap-On truck
Old Feb 20, 2007 | 11:37 PM
@ries's Avatar
Default Re: valve adjustment (92hondalude)
nice! i once welded a lug nut to the end of a 10mm deep socket. almost like your version.
Old Feb 21, 2007 | 04:43 AM
bluedlude's Avatar
Default Re: valve adjustment (@ries)
you should be able to pick up the jamb nut wrench from the snapon truck for like $25, then just use your own screwdriver.
Jimster480
10
Apr 16, 2010 05:52 AM
Powered by VTEC
16
Jan 20, 2008 03:47 PM
old_school_dohcvtec
Jun 30, 2007 06:57 PM
