Rear end sagging... ideas?
Old Feb 20, 2007 | 05:20 PM
RacerTim's Avatar
Default Rear end sagging... ideas?
I installed my stereo almost a year ago now. 3 amps, and 2 big kicker L7 subs. I would say it all weighs around 250 lbs. The back end of my 01 accord is now starting to sag pretty bad. I've been wanting to lower the car, and tell you the truth, the back end is sitting right about where I want it, about 2" lower. It just looks very strange because the front is still the normal height. Anyways, would this be affecting the rear camber at all? With more than stock weight in the back, what options do I have for lowering the car and getting it to sit even? I was thinking about going with a shock/spring combo to lower it, but I'm afraid if I don't get adjustable parts, it will still sag. Air ride is not an option, this is my DD.
Thanks!
Old Feb 20, 2007 | 10:36 PM
shadow_ridge's Avatar
Default Re: Rear end sagging... ideas? (RacerTim)
my 98 did the same thing, im not sure if it did tamper with the tire ware(but my tire looked like it diped a lil inside). I redid my springs and struts and only had a 1.5 drop all around.
the First day my car was back to stock with the new springs, i was like wth? after a week it went back where i started ..haha
My rear springs where just worn out
Old Feb 21, 2007 | 11:40 AM
RacerTim's Avatar
Default Re: Rear end sagging... ideas? (shadow_ridge)
well do you think a good shock/spring combo will hold up then?
Old Feb 21, 2007 | 03:28 PM
hondadude's Avatar
Holy Cow;
I saw the title of the post and was going to suggest that you buy her a gym membership.
Old Feb 21, 2007 | 04:11 PM
Hammer99ex's Avatar
Default Re: Rear end sagging... ideas? (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">Holy Cow;
I saw the title of the post and was going to suggest that you buy her a gym membership. </TD></TR></TABLE>
ok well now that ive spit my beer all over my computer screen....
yea, aftermarket springs should give you a boost in the **** end. seems to me with all the weight in the trunk, the stock springs are not up to task. id def. go with something a bit stiffer.
and as for camber, yes your tires will wear funny if the sagging rear is prolonged. the suspension geometry wasnt necess. meant to have subs and amps above it.
Old Feb 21, 2007 | 05:30 PM
RacerTim's Avatar
Is it possible to get a much stiffer spring and still a lowering spring though? Any recommendations?
Old Feb 21, 2007 | 07:16 PM
361 accord's Avatar
Default Re: (RacerTim)
im still pretty fresh to suspension ill admit, but myaybe you should give ground control a CALL tell em what up, and they (i wish, maybe idk) should be able to point u in the right direction
from what ive heard GC does their shizzle completely custom using eibach springs...
Old Feb 22, 2007 | 10:59 AM
RacerTim's Avatar
anyone else?
Old Feb 22, 2007 | 01:14 PM
AJ06's Avatar
Default Re: (361accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 361accord &raquo;</TD></TR><TR><TD CLASS="quote">im still pretty fresh to suspension ill admit, but myaybe you should give ground control a CALL tell em what up, and they (i wish, maybe idk) should be able to point u in the right direction
from what ive heard GC does their shizzle completely custom using eibach springs...</TD></TR></TABLE>
U can call GC and get custom spring rates... they are baddass
Old Feb 25, 2007 | 06:48 PM
RacerTim's Avatar
what do custom setups run from them? I don't have an arm and a leg to spend!
rmiller
Jun 1, 2008 03:57 AM
tsouyporta
May 4, 2006 12:05 PM
ELSpool
Apr 28, 2006 11:10 AM
Mike1486
Feb 10, 2005 09:10 PM
integranator
Sep 18, 2004 12:59 PM
