FS / WTT: Built D16 turbo setup
I'm looking to trade my turbo d16 setup with custom turbo kit for a COMPLETE b-series swap.
Here's what is on my side of the bargain:
D16Z6 head:
Decked, exhaust side ported.
Comp cam 59300 cam.
Comp cam valvesprings/retainers.
Edelbrock cam gear.
OEM honda valvestem seals and cam seals.
Edelbrock D16z6 intake manifold
Needs a throttle body
D16A6 block
Not charging for this because #3 cylinder is cracked. What you want is the internals:
SRP 8.5:1 pistons.
Eagle rods, look like they just came out the box. They are the newer models with the ARP 3/8 12pt bolts.
Stock OEM flywheel lightened to 12 lbs.
Unorthodox lightweight red pulley.
OEM honda crank- micro polished.
All OEM main/rod bearings and thrust washers.
All of the internals have been balanced/ blueprinted.
Turbo Kit
T25 turbo w/adapter plate on std manifold
Johnny racecar intercooler
DSM 450cc injectors w/resistor box
DSM 1st gen BOV
All charge pipes, stainless steel braided lines, and fittings included.
190lph fuel pump
Put this all together and you have a complete monster. I have receipts for most of the stuff. I'll have to rummage around for them.
I don't want to part this out just yet.
Once again, I would idealy like to trade this for a complete B-series swap. Let me know what you have to offer.
I am located in Vancouver, BC Canada eh!
D16Z6 head:
Comp cam 59300 cam.
Edelbrock cam gear.
D16A6 block
SRP 8.5:1 pistons.
Turbo Kit
DSM 1st gen BOV
190lph fuel pump
W O T
Feb 13, 2005 03:10 AM
