Service Check Connector???????????
I posted this in the Integra forum with no input, I know someone in here will know..
I was checking my timing today and as the manuel says I put a Jumper into Service Check Connector... and set the timimg accordingly. Then just for ***** and giggles, I cut the car off pulled the jumper wire from the SCC and rechecked the timing, well there was no change. So the question is; what is the piont of jumping this connection????
Thanx for any info.
Thanx for any info.
It will prevent the car from putting any timing in. so if it wanted to advance or retard the timing it wont. most of the time your going to see just what you did tho..
BoostedGSRBubble
Nov 18, 2001 09:25 AM
