z6 intake mani on y7
tried searching but can only find threads on the y8 mani swap. anyways, wanting to know what mods i'd have to do for a z6 intake mani to work on my 99 y7. thanks in advance...
You have to tee or eliminate one of the small coolant line that goes to the z6 intake....there is one less nipple coming off the water pump tube on the y7....thats all I had to do to make it work.
I know you can block certain coolant passages off but not sure which ones...I just used a brass tee into one of the other line to feed the open passage. There was only one extra spot I needed to hook up so teeing it worked fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03akkord5spd »</TD></TR><TR><TD CLASS="quote">so block off the coolant passages on the rear of the z6 plenum and that's it? any issues with iacv wires like on a y8 mani?</TD></TR></TABLE>
Your going to run into the same problem, you need to block the IAC on the back of the manifold and run your throttle body.
StuckInTexas
Feb 12, 2015 10:38 PM
Red_ED8
Apr 30, 2008 05:22 AM
92civic_eg
Aug 18, 2004 06:24 PM
