Difference b/t auto ECU and Manual ECU?
Old May 20, 2002 | 03:07 PM
See Are X's Avatar
Default Difference b/t auto ECU and Manual ECU?
what are the differences?
Old May 20, 2002 | 03:28 PM
salbaje's Avatar
Default Re: Difference b/t auto ECU and Manual ECU? (See Are X)
if you have an auto ecu in a manual car it will throw a code 18.
Old May 20, 2002 | 04:54 PM
91 Civic B16's Avatar
Default Re: Difference b/t auto ECU and Manual ECU? (salbaje)
i was running an auto ecu and didnt get any codes like that, but what i did notice was that vtec engaged earlier and my fuel cutoff was at 7500 rpm. also, when i opened the ecu, the smaller board inside was marked with an AT. i run a pr3 ecu.
[Modified by 91 Civic B16, 1:55 AM 5/21/2002]
Old Dec 11, 2010 | 05:15 PM
akadiablo's Avatar
Well i guess if I was to use a pr3 auto on my b20with a gsr head would be great since the b20 can't and won't handle much rpm! I guess an auto would be better for this set up instead of the manual atleast till I have the money to convert to a obd1 setup!!!
akouznet
May 24, 2009 06:50 PM
lococoin
Jan 31, 2005 12:15 PM
tunes12
Jun 17, 2003 10:25 AM
