i need help with my ek
Old Feb 19, 2007 | 10:21 PM
ek9.5's Avatar
Default i need help with my ek
Hi im new to honda tech. I need help with my car. I dont know if i bleow my engine or something. one time i was racing a civic. Later that day my car just stop. i turn it back on and it made this strong sound it sounded like a car with no pipping. i turn it back on and it woudnt star so i gave it some gas and it turn back on and turn off. the oil light and the battery light turn on. know it make this weard noise and it wount star at all. my engine is a jdm 1993 b18c. my ecu is a p28 it revs up to 9 1/2 i dont know what to do
Old Feb 19, 2007 | 10:31 PM
b16nonoy's Avatar
Default Re: i need help with my ek (ek9.5)
if there is a check engine light...see what codes you have....did you over rev or anything? anymore details to help us help you
Old Feb 19, 2007 | 10:52 PM
ek9.5's Avatar
Default Re: i need help with my ek (b16nonoy)
no, i rave up 2 8 1/2. but my ecu revs up tp 9 1/2. it shows a check engine light cuse my obd1 ecu
Old Feb 20, 2007 | 03:49 AM
bart2546's Avatar
This is going COMEPLETELY out on a limb here but the comment you made about it sounding like a car with no piping...if you're referring to it sounding like there is no exhaust on it...that kinda sounds like a spun rod bearing to me..but some more detail is needed. Now that you're basically at rock bottom of the car running, start from the bottom and go up. When you turn the key is your fuel pump still priming? Do your interior lights/dash lights/radio all still come on/work? Does the car crank at this point and not turn over or does it not even crank?
Old Feb 20, 2007 | 07:44 AM
ek9.5's Avatar
yes all the light turn on. but the cluster kind of dies and it shows battery light and the oil. it cranks but i have to press on the gas a littile bit. thats when like the cluster goes out. yea the pump still priming
Old Feb 20, 2007 | 08:16 AM
93eg2james's Avatar
I'm with bart, sounds like you spun a rod/main bearing...
When you start the car does it make a noise that sounds something like someone is hitting your motor with a hammer? If so it sounds like a main bearing to me.
Reason I think this is as follows: If the car starts and then dies quickly, its usualy due to loss of electrical power somewhere along the line. If a main bearing is gone, it makes it very hard for the rotating assembly to turn as it normally would, causing th crank to move slow enough to not supply enough power through the alternator which in-turn feeds the distributor. No spark, no car...
quakerE30
Nov 12, 2012 05:25 PM
dojo19xx
Honda S2000
Oct 21, 2011 10:46 AM
Maxcapacity
Aug 25, 2008 11:41 PM
ImportPower13
26
Mar 3, 2005 03:31 PM
iGoneRacing_GSR
Nov 17, 2003 08:25 AM
