s2000 Cluster in My Ek
Old Feb 19, 2007 | 08:33 PM
djpepsi's Avatar
Default s2000 Cluster in My Ek
S2k cluster finally finished.
Old Feb 20, 2007 | 12:28 AM
MrDark's Avatar
Default Re: s2000 Cluster in My Ek (djpepsi)
Let me be the first to say.....
I hate you!
Looks damn sexy!!
Old Feb 20, 2007 | 07:15 AM
redtop22's Avatar
Default Re: s2000 Cluster in My Ek (MrDark)
wow, looks great! get an s2k steering wheel to match it
Old Feb 20, 2007 | 08:32 AM
MrDark's Avatar
Default Re: s2000 Cluster in My Ek (redtop22)
This should be the part where you share all your wisdom on S2k cluster swap!!! So I can do one!
Old Feb 20, 2007 | 09:13 AM
vltnolia's Avatar
Its just so lovely..
Old Feb 20, 2007 | 01:22 PM
djpepsi's Avatar
its not to hard, as it looks.
first off all u need a stock ek cluster and use the frame that bolts up to the factory wholes and u put the s2k cluster in it and glue around it, and then make a trim for the gaps around the s2k cluster either use CF, or use abs plastic, i used abs plastic then used a vinyl cf sticker cheaper that way. rest is wireing.
Old Feb 20, 2007 | 01:43 PM
EK FLY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djpepsi &raquo;</TD></TR><TR><TD CLASS="quote">its not to hard, as it looks.
first off all u need a stock ek cluster and use the frame that bolts up to the factory wholes and u put the s2k cluster in it and glue around it, and then make a trim for the gaps around the s2k cluster either use CF, or use abs plastic, i used abs plastic then used a vinyl cf sticker cheaper that way. rest is wireing.</TD></TR></TABLE>
how about vss signal and all that **** ?
Old Feb 20, 2007 | 02:31 PM
djpepsi's Avatar
Default Re: s2000 Cluster in My Ek (super-hatch)
vss to work u need a a to d converter, http://www.dscustoms.com sells it for 180$ shipped american. and then for the temp u need a aem ect 80$. and everthing else is fully functional. ur car will look better and make more $ when u sell ur ride .
Old Feb 21, 2007 | 03:45 AM
KYLE.'s Avatar
Looks good
Old Feb 21, 2007 | 08:23 AM
yaoming315's Avatar
i kinda don't like seeing those clusters on Ek.. the cluster is sitting to straight, and you're looking at it directly at it. If you notice on the real s2000, the cluster sits at an angle slanted away from you. just looks kind of odd with the cluster sitting perfectly perpendicular like that.
Old Feb 21, 2007 | 09:35 AM
high_revs's Avatar
f*cking clean, more pics bro
Old Feb 21, 2007 | 02:07 PM
Airbag Club's Avatar
Default Re: s2000 Cluster in My Ek (yaoming315)
so were most of the wires that you soldered to, the same corresponding colors? also, what is an AEM ECT?
Old Feb 22, 2007 | 05:05 AM
bseries_ben's Avatar
Default Re: s2000 Cluster in My Ek (ARC Magic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARC Magic &raquo;</TD></TR><TR><TD CLASS="quote">so were most of the wires that you soldered to, the same corresponding colors? </TD></TR></TABLE>
no, there's like 4 plugs that come out of the s2k cluster and they all match up to different color wires depending on what car it's going into. some kid has an ap1 chart up to an eg, ek and ef i believe maybe a dc, but not sure. it doesn't really look that hard. looks like mounting it cleanly is the hardest part, it's been around long enough now that people figured out all the hard **** and you can just pay to make it work. as soon as i get my eg, im gettin an ap2 cause they're teh hawtness
Old Feb 22, 2007 | 08:53 AM
yee SERIOUS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARC Magic &raquo;</TD></TR><TR><TD CLASS="quote">so were most of the wires that you soldered to, the same corresponding colors? also, what is an AEM ECT?</TD></TR></TABLE>
here's the wiring schematics:
http://www.dscustoms.com/s2kpages/wiring.htm
the AEM ECT is AEM's engine coolant temperature converter i believe. i think a lot of AEM EMS users have it to convert their temp gauge for datalogging and such. someone correct me if i'm wrong.
just about all details about installing an s2k cluster can be found on this page: http://www.dscustoms.com/
Old Feb 22, 2007 | 09:04 AM
Default Re: s2000 Cluster in My Ek (undercoverdc2)
they don't have the ap2 pinouts tho
Old Feb 22, 2007 | 09:22 AM
Default Re: s2000 Cluster in My Ek (clover99b18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clover99b18c1 &raquo;</TD></TR><TR><TD CLASS="quote">they don't have the ap2 pinouts tho</TD></TR></TABLE>
look closer: http://www.dscustoms.com/s2kpages/ap2pinouts.htm
Old Feb 22, 2007 | 09:26 AM
hahaha. guess im the idiot. don't know how i missed that. just didn't scroll down far enough. thanks
Old Feb 22, 2007 | 10:34 AM
SilverCoupeEj8's Avatar
good shyt!
Old Feb 22, 2007 | 10:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clover99b18c1 &raquo;</TD></TR><TR><TD CLASS="quote">hahaha. guess im the idiot. don't know how i missed that. just didn't scroll down far enough. thanks </TD></TR></TABLE>
haha, i didn't see it til you mentioned ap2, so i just went to go look. lol
Old Feb 22, 2007 | 11:48 PM
ek4kid's Avatar
i did the exact same thing, i used my ek plastic border outta my ek cluseter and put my s2k cluster in it, and tried to mount the holes on the ek border and my s2k cluster would hit the back of the huge plastic heater/air vent... so im wundering how u managed to fit it together. if u didnt mount the s2k cluster but mounted the Ek plastic border,,? if that makes sence at all..
Old Feb 23, 2007 | 06:27 PM
birdzo2k2's Avatar
Default Re: s2000 Cluster in My Ek (ek4kid)
what exactly is soldered??? i'm a noob so i have no idea what's up...lol...i just want to do it to my 98 accord!!
Old Feb 24, 2007 | 12:47 AM
zerovandez's Avatar
how the hell do you get it to mount?! looks hella good!
Old Feb 24, 2007 | 04:34 AM
Default Re: s2000 Cluster in My Ek (birdzo2k2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by birdzo2k2 &raquo;</TD></TR><TR><TD CLASS="quote">what exactly is soldered??? i'm a noob so i have no idea what's up...lol...i just want to do it to my 98 accord!!</TD></TR></TABLE>
about 40 wires
Old Feb 24, 2007 | 11:45 PM
birdzo2k2's Avatar
were the directions at dscustoms pretty straight forward?? or what?
Old Feb 25, 2007 | 12:08 AM
pos_cd5's Avatar
looks good! now just get a nice steering wheel (s2k steering wheel possibly) to compliment the new cluster. btw i have the same air fresherner, when new the scent is too damn strong and hurts my nose
