Looking for headlight air intake kit - need some help
Have a 97 ITR road race car. looking for a headlight air intake kit but can't find one anywhere. anyone know who makes them or what is needed to make one? I don't have an engineering background, so i need some help.
thanks in advance.
cheers
thanks in advance.
cheers
Shouldn't be too hard. Get a velocity stack, some ducting and tubing. Take out the passenger side hi-beam light and stick the stack(filter too if you like) in there. Run some ducting to a intake tube. That should work for you
Somethin like this?????
Mine is a DIY. Buy an short ram intake, Go to home depot and buy 3 inch pvc piping, about 2 feet or 3 doesn't matter you will cut to fit either outside the bumper like mine or inside the bumper. At the end of the pipe throw on your filter or flow stack.
The Realtime race team used an NSX airbox with a duct coming from the headlight hole http://www.team-integra.net/fo...ion=4
First and foremost, hanks for the help!!!
Yes, USDM front end.
On the NSX airbox set-up on Realtime. What would I need to get, the hose from the TB to the airbox, the airbox (not sure of the parts I need for the actual airbox) and something from the airbox to the headlight. I see the parts for the NSX, just don't know which are needed and not needed...see link below.
http://www.acuraparts247.com/p...ch=no
Estoril73
Welding / Fabrication
Oct 26, 2017 11:58 AM
What make/model intake tube will end directly behind my headlight?or directly befind my passenger si
EJ8chu
10
Feb 8, 2008 08:33 AM
just4fun
Feb 22, 2007 09:54 PM
jdmspoonitr
Oct 30, 2003 08:20 AM
