rear 97 type R calipers
Old Feb 19, 2007 | 05:44 PM
huge230's Avatar
Default rear 97 type R calipers
Can these be interchanged with 94+ calipers given both are being changed?
Old Feb 20, 2007 | 03:54 AM
huge230's Avatar
Default Re: rear 97 type R calipers (huge230)
would prelude rotors redrilled work with these just like on the front?
Old Feb 20, 2007 | 05:31 PM
Dogginator's Avatar
Daisy... Daisy...
No, the Prelude rear rotors are 10mm thick and the ITR are 9mm thick. The offset is off as well. Check this site for dimensions:
http://www.dba.com.au/dba_cata...6.pdf
The link may drift over time. The base site is the same.
Old Feb 21, 2007 | 06:15 PM
FIGARILA's Avatar
so you are trying to put base integra rear calipers on the type r bracket?
Old Feb 22, 2007 | 04:31 AM
IN VTEC's Avatar
The trailing arms are different. The caliper brackets won't bolt up.
salesman
Mar 11, 2009 11:07 AM
SOHC_me
Oct 9, 2006 01:51 AM
Ill
Nov 1, 2003 08:02 AM
QWKPHKR
Feb 21, 2003 09:47 PM
QWKPHKR
Dec 30, 2002 06:25 PM
