h22a4 into ej questions
ive got a 98 h22a4 i want to swap into an ej civic. about how many hours would be involved in this swap? what will i need as far as ecu, wiring harnesses/jumper harnesses, shifter cables, and anything else needed? any help is appreciated.
i didnt find any useful information. both motors are obd2 so that shouldnt be a problem unless theyre a different obd like obd2a and obd2b. can i use the harness and ecu from the prelude? ive also heard the a4 is a little harder to get to work. dont reply if all youre going to say is search. thats such an out for people that dont know the answers to the questions and want to have a post.
another newb question on top of the others. is theyre any difference in the ej and ek chassis that would stop me from using an ek h22 swap guide? and am i going to have a problem with the a4?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88ED8 »</TD></TR><TR><TD CLASS="quote">check this link out https://honda-tech.com/zerosearch
stop being an *******
</TD></TR></TABLE>stop being an *******
why cant people just answer simple questions? it is because the ones that come in here and say search really dont know anything about h swaps? i have a ton of questions and i dont feel like digging through a thousand threads for answers. for the ones trying to help, will this swap work the same as an ek chassis h swap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _unclejuice »</TD></TR><TR><TD CLASS="quote">why cant people just answer simple questions?</TD></TR></TABLE>
because your gay, and you should serch like the rest of us
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _unclejuice »</TD></TR><TR><TD CLASS="quote">it is because the ones that come in here and say search really dont know anything about h swaps?</TD></TR></TABLE>
sounds like your the one that doesn't know anything about the H swap
WOW your so gay!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _unclejuice »</TD></TR><TR><TD CLASS="quote"> what about axels? and for the ecu and wiring</TD></TR></TABLE>
Because your so gay I'll TRY to help, I've herd that you can use a 90-93 Accord half shaft with 90-93 integra axles I can't confirm this since all I *** with are crX's but it's worth searching in to...
wiring... thats very easy keep it simple, use your engine harness from your '00 civic modifiy it to work with your H22 then get a obd2-obd1 conv. harness, ECU just get a chipped P28, if it were me I'd also get hondata so when then swap is complete you can tune it for max performance
and seriously, search it really does help allot!!!
WOW your so gay!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _unclejuice »</TD></TR><TR><TD CLASS="quote">thanks for your childish but useful thoughts. i found hasport axels that use the preludes intermediate. ill see what i can find as far as ecus go.</TD></TR></TABLE>
what? bro all hasport axles are is h22 inners with civic/integra outer...same thing we do except theirs might just be stronger...you would have to use prelude halfshaft either way..
MTracing
Mar 29, 2012 01:11 PM
