Which B series for more Power With a Built head?
Old Feb 19, 2007 | 09:34 AM
ROCAFELLA2049's Avatar
Default Which B series for more Power With a Built head?
I'm a turbo guy so this is new to me. My friend is building an all motor car and we were wondering if there is a real performance difference between a JDM GSR with a built head or a JDM Type R with a built head. We have the option to buy either and are wondering is its worth it to go type r or stick with Gsr for the built heads. Any insight would be great. Thanks.
Old Feb 19, 2007 | 09:48 AM
drift4jesus's Avatar
Default Re: Which B series for more Power With a Built head? (ROCAFELLA2049)
ITR has higher compression pistons and has better rods (or at least they have a nifty 'R' cast into them and the bolts are dimpled to be tightened with a stretch gauge instead of just torqued) The crank is supposed to be slightly better as well.
If you don't feel like tearing apart a bottom end then stick w/ the itr. Go with the gsr if you plan to tear it down and build it later on.
Old Feb 19, 2007 | 10:26 AM
gibsanez's Avatar
Default Re: Which B series for more Power With a Built head? (drift4jesus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift4jesus &raquo;</TD></TR><TR><TD CLASS="quote">
If you don't feel like tearing apart a bottom end then stick w/ the itr. Go with the gsr if you plan to tear it down and build it later on.</TD></TR></TABLE>
Why spend the extra cash on the same block if you plan to rip out the pistons and cams anyway? I vote GSR.
jdmgeezer
Feb 11, 2008 06:40 PM
hondapwr1621
23
Apr 14, 2005 09:45 AM
JdmEg6Hybrid
10
Sep 7, 2004 09:36 PM
No
Feb 8, 2004 12:19 PM
pootie.teng
Oct 22, 2003 12:09 PM
