17x8 Wheels... What off set Needed??
Alright guys I bought some 17x8 Wheels and wondering off set am I going to need for these wheels not to rub... I already searched and came up with nothing... Any help appreciated. They are for a 5th gen btw.
You bought them but don't know what offset you need. Are you hoping one of the answers will be the offset of the wheels you bought.
third time in like 2 weeks ive posted this....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 »</TD></TR><TR><TD CLASS="quote">copied from: http://www.ottawaprelude.ca/ya...=2886
OFFSET:
6.5" Wide Wheels w/ 4th & 5th Gen
Less than +38mm ::: You take the chance of rubbing the outside lip of the wheel well.
+38mm to +55mm ::: You shouldn't have any problems. Recommended Offsets for 6.5" Wide Wheels.
Larger than +55mm ::: You take the chance of rubbing the inside lining of the wheel well.
7" Wide Wheels w/ 4th & 5th Gen
Less than +38mm ::: Not Recommended
+38mm to +41mm ::: Not Recommended if you are, or plan to be, lowered. You take the chance of rubbing the outside lip of the wheel well.
+42mm to +44mm ::: This is a grey area if you are lowered, results vary depending on tire and/or drop. You take the chance of rubbing the outside lip of the wheel well.
+45mm to +50mm ::: You shouldn't have any problems. Recommended Offsets for 7" Wide Wheels.
Larger than +51mm ::: Not Recommend. You take the chance of rubbing the inside lining of the wheel well.
7.5" Wide Wheels w/ 4th & 5th Gen
Less than +40mm ::: Not Recommended
+40mm to +43mm ::: Not Recommended if you are, or plan to be, lowered. You take the chance of rubbing the outside lip of the wheel well. Wouldn't recommend using any tire with an overall diameter larger than stock and/or with a tire width larger than 215.
+44mm to +47mm ::: This is a grey area if you are lowered, results vary depending on tire and/or drop. You take the chance of rubbing the outside lip of the wheel well. Wouldn't recommend using a tire with an overall diameter more than slightly larger than stock, you chances of rubbing increase.
+48mm to +52mm ::: You shouldn't have any problems. Recommended Offsets for 7.5" Wide Wheels.
Larger than +53mm ::: Not Recommend. You take the chance of rubbing the inside lining of the wheel well.
8" Wide Wheels w/ 4th & 5th Gen
Not recommended without enlarging or rolling outside lip of wheel wells. Some people have had success with running offsets larger than +48mm, but you are taking an expense risk.
OFFSET:
Thank you but it says 17x8 Not recomemnded.... a lot of help that does me I was wondering if anyone else has had experience with 17x8 wheels and what off set they were running I have seen that chart before and had no info for me but hey thanks!!
Black R
Jul 16, 2005 05:28 AM
