Ok, I have one quick question about the FITV.
Ok, So. Im putting in a built H22a into my 2000 Prelude.
I have a Skunk2 70mm Throttlebody. The FITV isnt compatible, I know.
Tomarrow I will be finishin up on pulling my old motor and putting the new one in.
I have a P72 & a Hondata S200 for the ECU & tuning system.
Will I have the crazy Idle surging problem, if yes. How do I fix it?
I did use the search, I found one thread, but it didnt answer my question.
Sor all of you Crazy people out there...I know I am going to be asked for this...so heres the engine mod list. (Yes, note the S2 Manifold - its the 2006 PRO spec)
AEBS Triple Cam Seal
AEM Fuel Pressure Regulator (silver)
AEM Fuel Rail (silver)
ARP Head Studs
ARP Rod Bolts
Balance Shafts Removed
Brand New Bearings, Thrusts, Gaskets, Seals, etc.
Clutch Masters 8lb Flywheel
Clutch Masters Stage 3 Clutch
Complete Race Headwork by PORTFLOW
Greddy Evo 1 Exhaust System (2.5" piping, no resonators and no Cat....straight back 2.5"
GReddy Upgraded Strong Reinforced Blue Timing Belt
HONDATA Intake Manifold Heatshield Gasket (Port Matched)
Hot Tanked, Precision Bored
IBSpec Wiseco custom 12.5:1 88mm Forged Pistons (deep valve reliefs)
IBSpec/Portflow Port & Polish Stage 3 Competition Race Package
Magnecore 8.5mm Wires (red)
Micropolished and Custom Crankshaft work
New IBSpec Super Piston Rings
New OEM Honda Oil Pump
New OEM Honda Water Pump
New OEM Throw-out Bearing
Cometic 88mm Headgasket
Probe ULTRALITE Rods (lightest H22A forged rods)
Prodrive Billet Oil Pump Gear
Professionally Balanced, Blueprinted, and Assembled
RC 440cc SAT. Injectors
RS Machines Sleeves, Overbored to 88mm
SKUNK2 0.5mm Oversized Black Nitrited Race Valves
SKUNK2 Intake Manifold (Port Matched)
SKUNK2 Race Valve Springs
SKUNK2 Silver Adjustable Camshaft Sprockets
SKUNK2 Stage II PRO Series Camshafts (upgraded them from the "regular" Stage 2's that were in there to start)
SKUNK2 Titanium Retainers
SKUNK2 70mm Throttle Body (Matched)
Walbro 255lph High-Pressure Fuel pump
RMF DRAG Header (2.5" collector)
JDM Type-S Intake
K&N DROP IN
Unorthadox Crank Pulley
Unorthadox P/S Pulley
P72 GSR ECU
Hondata S200
Boomslang Conversion Harness
Apexi' VAFC 1
Im excited..I cant wait to see what this beast makes. Everything on that motor is new, never been started....I just wanna make sure nothing is going to explode when I start it, and take my house with it..haha.
Thanks all.
-Max
ARP Head Studs
ARP Rod Bolts
)GReddy Upgraded Strong Reinforced Blue Timing Belt
JDM Type-S Intake
K&N DROP IN
P72 GSR ECU
Hondata S200
Apexi' VAFC 1
Thanks all.
-Max
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00mugenlude22 »</TD></TR><TR><TD CLASS="quote">
Will I have the crazy Idle surging problem, if yes. How do I fix it? </TD></TR></TABLE>
If you have a crazy idle surging problem, it won't be from the FITV.
I don't see why you would have any surging issues as long as the FITV is connected. Also I'm a little confused on your setup, you have hondata AND a VAFC? I don't know why you wasted the money on a P72, also all this money on a build and you're using Probe rods? Saturated injectors? And lastly, although not nearly as important as the first few, it might be better to go with a CAI with a BPI and K&N
you don't need an FITV as was said.
the 2006 PRO spec (lol you capitalized it) skunk2 IM is just the same as the old one with cleaner casting. Good luck with that waste of money.
Probe rods are crap, and they're NOT the lightest rods available. You should have looked into carrillo for rods. Also, that crappy unorthodox pulley is going to ruin your freshly built bottom end, look into a real damper like the ATI or just use a stock pulley.
And you didn't need to go oversize on the valves, but hey its a little late for that now.
Im not interested in a CAI. I like how the Type-S looks. If you dont like it, your problem. My car. haha :thumbsup:
Inregards to the oversized vlaves & the PROBE Rods, I bought the motor assembled....well, I had to put the head onto the block and re-adjust everything...so thats not my doing.
As for them being the lightest rod....thats what I was told when I bought the motor...if they arent, meh..whatever.
I knew I was gonna get **** for the S2 manifold. Thats what I wanted, I dont care if it loses a lil power. It looks bling, and this is more-or less for shows. Again, my car, my motor...you don't like it? Tough ****. Dont buy it for yours then.
Im in it for performance, ya, but not completly, im not gonna be racing around town with it.
My friend have the Unorthadox crank pulley on his lude for 80K miles and he's had no problems. As I said...bling factor. haha. :shruggs:
The P72 and the S200 came in a package deal. The S22 is brand new, so im not worried about it.
As for the Saturated injectors....I called RC, talked to one of their guys for like 30 mins, sent him my mod list, and they said that they thought that the Saturated would be best for my setup. I was relying on them. haha.
Last but not least, the FITV....I was doing some light reading before I posted this, and from what I understand, is that if you dont have the Fast Idle Thermo Valve hooked up, you will have an Idle surge until the car fully warms up.
As for them being the lightest rod....thats what I was told when I bought the motor...if they arent, meh..whatever.I knew I was gonna get **** for the S2 manifold. Thats what I wanted, I dont care if it loses a lil power. It looks bling, and this is more-or less for shows. Again, my car, my motor...you don't like it? Tough ****. Dont buy it for yours then.
Nah, I don't feel like an idiot. I know what I wanted, so I bought it. Im not worried about money.
I care to a certain point. I dont care if it makes 210whp or 250whp. But, I want it to atleast run right.
Also, I dont get the saying "Bling Bling lil weezy!?" That dosent mean anything to me.
Theres a large difference in the amount of money you need to spend for 210whp and the amount for 250whp.
You could have spent the difference on some blingin rimz or some ICE dawg.
Your priorities would fit in better on another forum, but, fwiw, I hope you got the answer you needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">Theres a large difference in the amount of money you need to spend for 210whp and the amount for 250whp.
Your priorities would fit in better on another forum, but, fwiw, I hope you got the answer you needed.</TD></TR></TABLE>
Ya, I guess I could have....But I like my SportMax 962's. Gold/ polished lip.
And, the sound system Im not to interested in doing. I rarely ever listen to it anyways.
Why dont you go get a job and earn your money?
But ya, I get your point, now get mine...Im not interested in having 200 amps & speakers, and im not interested in having a set of $2,000 wheels. The wheels I have now are awsome, why change? I just got them a month ago.
I just donated money to my carclub, so im capped with my donations for now. haha.
So. Does anyone have a actual ANSWER for me, or what?
What ******* answer do you want? I told you, <u>you don't need the FITV. I drive everyday without one and I don't have idling problems.</u>
From your uneducated manner about building engines and having horsepower not be your priority, I had supposed that you were simply building your engine so you can roll up next to your homeses and say "dis **** is built y0". Thats why I figured you would like huge subs and some rimz
I did some research and they told me that the FITV was causing the Idleing problem on my car, it jumps up and down from 1500 to about 3000 rpm or close, I changed the Map sensor and IACV, I checked the hoses for leaks, but everything seems to be ok. The problem goes away sometimes after I run the car for a while but comes back, or it will rarely drop the rpms and die, but that's very rare, I also checked the TB and it seems that the butterfly is properly closed. A lot of you guys know a lot about this so I would really appreciate some of your help since I've been having this problem for a while now, other than that, the car runs fine.
matt he didnt build this motor ill guarantee it. this sounds like the motor i was gonna buy from chaudanova. i used to talk to him all about this motor. he told me that the guy who bought the motor from him was some ***** that didnt know jack about cars n was probly gonna blow it up b4 it even got to its full potential. this must be the *****. if this aint u 00mugen then i apologize but u have an IDENTICAL build
dude after reading ur thread on socal ur a friggin jooooooooooooooooke, a fat slob. u have no idea wut u really have. bling this n bling that???? this motor is goin to waste with u!!!! it should be in some1s drag car at the track not ur "pimp mobile"
Z0831xiz
13
Nov 6, 2017 04:00 PM
crazydominicanman
29
Jan 31, 2010 10:20 AM
