ST adjustable rear sway bar question
Old May 20, 2002 | 10:52 AM
Steve91's Avatar
Default ST adjustable rear sway bar question
There are 3 holes to set the endlinks at, but I don't know which one does what? I need to know which direction softens or stiffens the bar.
Thanks
Old May 20, 2002 | 11:03 AM
RyanR's Avatar
Default Re: ST adjustable rear sway bar question (Steve91)
Further in is stiffer, further out is softer.
Old May 20, 2002 | 12:45 PM
Driven's Avatar
Default Re: ST adjustable rear sway bar question (RyanR)
This is a picture of the passenger side.
Move the bottom of the end link down to the next hole on the silver bracket, and it will stiffen the rear end (rotates easier).
Move the top of the end link further right (or towards the rear of the car)... it will stiffen the rear end.
Move the top of the end link further left (or towards the front of the car)... it will loosen the rear end.
sorry it's dirty... signs of a suspension that is used
Old May 20, 2002 | 12:53 PM
carsaregood's Avatar
Default Re: ST adjustable rear sway bar question (Driven)
is that bottom end link adapter thingy connected to the shock fork/lca what comes with the rear st swaybar? or is that custom?
Old May 20, 2002 | 03:42 PM
Steve91's Avatar
Thanks guys, I'll be doin' some adjusting tonight
Old May 20, 2002 | 05:27 PM
Driven's Avatar
Default Re: ST adjustable rear sway bar question (carsaregood)
comes with the ST swaybar kit... i believe it only works with 89-91s...
You have to hack off the welded nut on the shock...
Old May 20, 2002 | 05:33 PM
ivanED9's Avatar
Anyone install the rear sway bar from the ST Sway Bar Kit on an 88si?
Old May 20, 2002 | 05:38 PM
efvader's Avatar
Default Re: ST adjustable rear sway bar question (ivanED9)
My friend has one of his crashed rex. gonna pick it up I think for cheap. im gonna auto x it and daily drive it which setting do you boys think. Thanks Rob
Old May 20, 2002 | 06:22 PM
SpoonPL's Avatar
It fits on a 88, a guy in my auto-x club did it.
I don't know exatcly how, but it must not be that difficult, plan a trip to home depot or something.
PL
Old May 20, 2002 | 07:38 PM
jasonb's Avatar
Default Re: ST adjustable rear sway bar question (SpoonPL)
he most likely used 89-91 rear LCA's. same thing I did.
Old May 20, 2002 | 09:25 PM
Steve91's Avatar
For those of you that race your CRX in Autocross or Road Race, do you run a front sway bar at all? I've ran with and without the front bar but I get a bit too much oversteer without the front bar. My springs are #400F, #450 rear.
Steve
Old May 20, 2002 | 10:45 PM
manveer's Avatar
You might want to ask in the competition forum about that...(this forum's discussions usually center on drag racing)
But with my front swaybar connected and the S/T rear bar on I get a significant amount of oversteer. Some people have been very successful with running no front bar.
Ritchie
Suspension & Brakes
26
Oct 16, 2010 09:29 PM
Charlie Moua
Honda CR-V & Element
Jul 20, 2010 11:09 AM
chinochanginc
Feb 4, 2009 04:01 PM
