Power wire through the firewall ?
Old Feb 18, 2007 | 07:25 AM
cliffsta's Avatar
Default Power wire through the firewall ?
What's the best way to get the power wire (soon to be two power wires) for my amplifier(s) through the firewall on my 99 Accord EX 4-door sedan? There's a big grommet way down by the A/C stuff but there is closed loom going through it. Do I need to cut into that loom to go through? Is there a BETTER spot to come through?
There is a black plastic cap higher up on the firewall,and I popped it out to expose the backside of I assume the carpet/insulation. Is this a good place to just poke through?
Old Feb 18, 2007 | 08:35 AM
Tx_Accord98's Avatar
Default Re: Power wire through the firewall ? (cliffsta)
the best place that i have found on a 6th gen is the grommet underneath the engine fuse box. it runs right behind the glove box. if you use that one, you have to get a knife and poke it so you can run the wires. it will be to tight of a fit if you don't.
Old Feb 18, 2007 | 11:42 AM
AJ06's Avatar
he right
geoffme
Aug 7, 2008 05:40 PM
caliskier
Feb 2, 2008 10:44 AM
ekcivic9
Dec 20, 2005 02:22 PM
darkfx
Sep 1, 2005 06:49 PM
jadugartir
May 22, 2005 01:26 PM
