Questions on installing an HID kit.
I have a question. After getting a HID after market kit, how am I suppose to install it? I got the ballast, harness, and bulbs from a friend but he didnt have the instructions left. Im just wondering if anyones out ther that knows how to install it. Its a pilot Ballast by the way if that makes any difference. I just dont get where to put the black and red conductors to from the harnesses. Is there suppose to be a slot where i put it in? And I thought it was just plug and play.
Ooo and where would i find replacement HID kit bulbs?
Modified by datssoled at 1:07 AM 2/18/2007
The bulbs should go into the headlight like a normal one would. The wires from the bulbs should plug into the ballasts and that should be it. Biggest obsticale i came across was finding a good place to mount the ballasts.
edit: https://honda-tech.com/zerothread?id=1874242
Not sure if this will help much but you can kind of see how the wires go.
same with me, the ballasts where the only problem, I did them on a Jag S-type and it took about an hour and a half. good luck, you'll get it.
it didnt come with the mount so can i just tape it somewhere with electrical tape?
and here can i get some direct replacement HID kit bulbs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1rcany12 »</TD></TR><TR><TD CLASS="quote"> Biggest obsticale i came across was finding a good place to mount the ballasts.
yeah, that definitely was the most time consuming part.
GQ 05YellowEVO8
Feb 9, 2002 10:58 AM
