ECU for B20b swap?
Old Feb 17, 2007 | 03:53 PM
slammed00si's Avatar
Default ECU for B20b swap?
Hello i have been searching everywhere for an answer maybe yall can help. I am about to swap a b20b into my 95 hatch. It already has an ls swap but my question is what computor can or do i need to run the b20b? is it cool to use the ls or do i need to get it tuned? i plan on leaving it non vtec. Thanks in advance for any help
Old Feb 18, 2007 | 03:37 AM
Kevin's Avatar
Default Re: ECU for B20b swap? (slammed00si)
I run the stock computer, injectors in my '90 Integra with a jdm b20b. The car runs and idles like factory. My car is bone stock though, even the exhaust right now. It still needs to be fine tuned and eventually i'll be going with a chipped ecu, this was just to get the car on the road.
Old Feb 18, 2007 | 07:13 AM
Default Re: ECU for B20b swap? (gLok)
ok thanks for the response man. so just the stock ls ecu will be fine.
Old Feb 20, 2007 | 02:35 PM
anyone else with input?
Old Feb 20, 2007 | 06:32 PM
one bad dx's Avatar
Stock LS Ecu is fine just make sure you have a jumper harness for it. Incase you dont know thats a harness that will take your OBD-2 motor and make it alright to use in a obd-1 vehicle w/out swapping over distributors and the other stuff (if any??) into your chassis. They are like 50-70 dollars on here and you just plug it in to your wiring harness before your ECU.
Old Feb 21, 2007 | 10:25 PM
smileycvc's Avatar
Default Re: ECU for B20b swap? (one bad dx)
chipped p28 all obd-1 then tune your motor.
Old Feb 22, 2007 | 02:21 AM
Kevin's Avatar
Default Re: ECU for B20b swap? (smileycvc)
I went the cheap route with mine and used most of my stock parts including the obd0 distributor, stock injectors in the b20 rail, b20 fpr and stock exhaust manifold.
Old Feb 23, 2007 | 10:04 AM
Katman's Avatar
You can technically use a stock LS ecu (obd1 92-95 PR4/P74/or P75 ecu will plug right in to your EG) to power your B20, altho you won't be running the motor at its fullest potential because of lack of true B20 fuel/timing maps.
But if you want to run the B20 at its full potential in its stock form without any kind of ecu reprogramming, I suggest running a B20 ecu via OBD1-OBD2 jumper harness.
chap2556
Jan 26, 2009 12:36 PM
eg6boii
11
Aug 31, 2008 09:05 PM
BlueRex1020
10
Feb 28, 2007 06:05 AM
pkgwjai082
Feb 1, 2006 07:48 PM
89 pos
Mar 19, 2005 07:23 AM
