Ascot Aftermarket wheels
Gday guys,
I wanna put some 17 inch wheels on my 94 Ascot. I have no idea about wheels etc
So some questions,
Does anyone know the ascots stud pattern?
What sort of offset should wheels on this car have?
Anything else i should know before going out and buyin anything?!!
Cheers
So some questions,
Cheers
Ive never heard of an Ascot before (not a US market car), but Wikipedia says its essentially a 94-97 accord...
...which would put its stock tire size in the 185/70/14 - 195/60/15 range, on a 4x114.3 bolt pattern.
If you want to maintain your speedometer and odometer accuracy as well as effective gearing, 205/45/17 is about as close as youre going to get to doing so with a 17" wheel. The overall diameter (which affects speedo/odo/gearing accuracy) is less than 1/4% off stock.
No idea on offsets, hopefully someone else can chime in.
If wikipedia is wrong and the Ascot is not a different-market Accord, most likely all the above I typed is wrong and please disregard.
Good luck!
Good luck!
P-M-B,93EXsedan
Mar 13, 2014 07:33 AM
aklucsarits
Feb 11, 2005 05:15 PM
