i have a problem!! my cars a 92 the h22 is 97 i had 2 order a crank tdc and the plug do fit
i have a problem!! my cars a 92 the motor is a h22 is 97 i had 2 order a crank tdc and the plug dont fit my wiring harness on my h23 what do i do???
Using the h23 harmess already in the car is a good move dont worry about the crank trigger just use the original dizzy and wire harness in the car. Then all you would have to wire is vtec sol and pressure switch save yourself the headache and do it that way. Your making it harder then it is.
