4-door Accord with window issues...
Any idea if the window regulators for all four doors are the same or they different? My drivers side window for some reason only comes down an inch now and then makes this loud horrible noise. I'm thinking that the regulators for other other two in the back are the same as the front so I'm thinking that swapping one of the rear ones to the drivers side should work. But before I attempt I'd like to know if it'll actually work before I slave myself to only find out in the end its not compatible, lol. Any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJ06 »</TD></TR><TR><TD CLASS="quote">What kind of grease?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJ06 »</TD></TR><TR><TD CLASS="quote">What kind of grease?</TD></TR></TABLE>go to the dealer and get a spray can with straw. Silicone spray. Spray into the track with window down. good to go.
BUt I have never had the noise you describe, so it may not solve your problem. But it is cheap maintenance, so try it first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow »</TD></TR><TR><TD CLASS="quote">go to the dealer and get a spray can with straw. Silicone spray. Spray into the track with window down. good to go.
BUt I have never had the noise you describe, so it may not solve your problem. But it is cheap maintenance, so try it first.</TD></TR></TABLE>
thanks
thanks
xkrakenx
Apr 24, 2008 06:12 PM
