Simple Yes or No Question
Old Feb 17, 2007 | 10:22 AM
Boosted_JDM's Avatar
Default Simple Yes or No Question
Is the OEM Type-R side skirts different that the OEM 1994 LS Integra. Its hard to tell from the pic's I have seen, but the type-R guys should know this.
Old Feb 17, 2007 | 10:34 AM
Skelly's Avatar
yes
Old Feb 17, 2007 | 10:43 AM
OG undercover's Avatar
Default Re: Simple Yes or No Question (Boosted_JDM)
Maybe
Old Feb 17, 2007 | 11:00 AM
neo_'s Avatar
Default Re: Simple Yes or No Question (Titanium ITR)
Yes they are different. I believe only the ends of them are in a slightly different shape.
Old Feb 17, 2007 | 11:46 AM
PrinceAli132's Avatar
Yes they are different. Here some links with pics;
https://honda-tech.com/zerothread?id=1212136
https://honda-tech.com/zero...age=2
Non-ITR (these do not sit flush with the rear wheel well_
ITR (these sit flush with the rear wheel)
OEM Optional
Ali
Old Feb 17, 2007 | 12:45 PM
LunchboxZT's Avatar
Default Re: Simple Yes or No Question (PrinceAli132)
OEM optional FTW
for them being discontinued.
Old Feb 17, 2007 | 12:46 PM
Fomoco's Avatar
Yes
They are shorter, I had this problem not too long ago. If you happen to live in the bay area in cali a place called N1 concepts should have some.
Old Feb 17, 2007 | 02:30 PM
ITR640's Avatar
Im not 100% sure, but Im pretty sure the only difference is that the ITR's came painted from the factory.
Old Feb 17, 2007 | 03:25 PM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
Default Re: (ITR640)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LunchboxZT &raquo;</TD></TR><TR><TD CLASS="quote">OEM optional FTW
for them being discontinued.</TD></TR></TABLE>
x2
Old Feb 17, 2007 | 04:45 PM
Doostur's Avatar
Im sorta glad they are discontinued... cause i have a set
Old Feb 17, 2007 | 04:58 PM
RaceMyGhost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR640 &raquo;</TD></TR><TR><TD CLASS="quote">Im not 100% sure, but Im pretty sure the only difference is that the ITR's came painted from the factory.</TD></TR></TABLE>
you CLEARLY did not look at the pics posted above....
Old Feb 18, 2007 | 02:12 AM
sheekdude's Avatar
Default Re: (Doostur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doostur &raquo;</TD></TR><TR><TD CLASS="quote">Im sorta glad they are discontinued... cause i have a set </TD></TR></TABLE>
BASTARD...I'LL GET A SET ONE DAY
Old Feb 18, 2007 | 02:51 PM
rockbottom's Avatar
Default Re: (RaceMyGhost)
Actually, the only difference in the skirts is the ITR ones come factory painted. There was a debate recently and it was determained that the ITR ones are just mounted differently.
https://honda-tech.com/zero...age=4
If you notice he mounted 2 sets of ITR skirts and a set of GSR skirts and was able to mount all three sets both ways. The part numbers are even the same I believe.
Old Feb 18, 2007 | 03:38 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (rockbottom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rockbottom &raquo;</TD></TR><TR><TD CLASS="quote">Actually, the only difference in the skirts is the ITR ones come factory painted. There was a debate recently and it was determained that the ITR ones are just mounted differently.
If you notice he mounted 2 sets of ITR skirts and a set of GSR skirts and was able to mount all three sets both ways. The part numbers are even the same I believe.</TD></TR></TABLE>
Correct.
04631-ST7-310ZZ PANEL, R. SIDE SILL
04641-ST7-310ZZ PANEL, L. SIDE SILL
Old Feb 19, 2007 | 11:09 AM
4F_RiverOtter's Avatar
Default Re: (nsxtasy)
I measured two sets of skirts, and they are different in overall length. I have a 1997 Integra RS. Those skirts measured exactly 6 feet. A friend of mine has a 2001 ITR and his measured out to be 6 feet and 1/4 inch. I tried to adjust the clips and no luck. It comes up a 1/4 inch too short. Pictures to prove it.
Hey, maybe I will just take my front fender off so they will fit. Notice how Madness fitted them without a fender... hmmm. Unless our cars are different. Atleast that was what I came up with.
integraswtrde
Jan 14, 2009 08:17 AM
ev0luti0n
Feb 19, 2004 07:08 PM
civic91
Jan 6, 2003 12:06 PM
Understeer
Aug 28, 2002 06:33 AM
