why NOT to get that shitty AEM bypass valve
Old May 20, 2002 | 09:11 AM
Greyout's Avatar
Default why NOT to get that shitty AEM bypass valve
found this on PO.com... thought it was interesting....
apparently, someone tested it somehow and found that it opens up at WOT, regardless of water. sorta defeats the purpose of having a CAI.
also, its lets dirt in!
section of pipe before bypass installed
section of pipe AFTER bypass installed
AEM
[Modified by JDM LUDE, 6:11 PM 5/20/2002]
Old May 20, 2002 | 09:21 AM
Finest's Avatar
Default Re: why NOT to get that shitty AEM bypass valve (JDM LUDE)
AEM
Actually, AEM =
Bypass =
Run the cold air setup and just don't go swimming with your car.
Or else just bring it up under the hood, but make a heatshield type barrier to isolate it from the engine heat. You can even run a duct that channels fresh air in the lower fenders and front bumper area to the filter itself. Personally, I would just leave it down there.
Old May 20, 2002 | 11:16 AM
TW00Si's Avatar
New User
Default Re: why NOT to get that shitty AEM bypass valve (Prelude_RCR)
I've told so many people NOT to get the by pass valve, but do they listen? NO. I had a CAI on my 00 Si and never had a problem driving through storms. The idea is not to take off the liner which some people do and not to go into deep waters thinking you are driving a boat. I don't...some people won't believe you till they see it themselves...
Old May 20, 2002 | 11:26 AM
Finest's Avatar
Default Re: why NOT to get that shitty AEM bypass valve (TW00Si)
I think the ONLY drawback with the CAI location is that you have to clean your filter more often. I check it every other oil change (6k miles). If it's somewhat dark (usually after 10k miles), I'll just clean it with the K/N filtercharger kit. Comes out clean and almost like new. Other than that, no regrets here!
Old May 20, 2002 | 12:22 PM
Prelude Vtec 23's Avatar
If your intake is completely submerged and you drive through a flood no bypass valve will prevent water from getting in. The only thing it may do is delay it. If you see a flood or puddle of water dont drive through it.
Old May 20, 2002 | 01:08 PM
apexii's Avatar
Wow you have no idea!! I have the 3" aem w/bypass on my ITR and man does it suck. I've had it off for 3-4 months now, and I just got a 3" silicone adapter to nix the POS bypass valve altogether. I was going to reinstall but I noticed my piping is dirty as hell and the filter is even dirty on the INSIDE. I'd hate to find out what made its way into my precious engine!
I'll take some pics when I get home...
Old May 20, 2002 | 03:09 PM
PrecisionH23a's Avatar
Default Re: why NOT to get that shitty AEM bypass valve (Prelude Vtec 23)
i had the aem cai on my prelude about 2 and a half years ago and i loved it. if you dont go boating in your car, you wont flood your motor. maybe things have changed in the past 2 years... I think super street or scc had a write up testing the bypass valve on the nsx, they actually had the filter IN water and it sucked up absolutely NO water. anyways, just thought id share that with everyone.
Old May 20, 2002 | 07:40 PM
ELUD THS's Avatar
New User
Default Re: why NOT to get that shitty AEM bypass valve (GudeH23a)
man never realized how dirty the bypass valve can make your cai
Old May 21, 2002 | 01:35 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: why NOT to get that shitty AEM bypass valve (ELUD THS)
i took mine off cause a damn piece of rubber from that thing got sucked into intake manifold, went through the combution chamber, fouled my $60 denso plugs, and it's now probably stuck somewhere in my cat.
bypass valve
Old May 21, 2002 | 02:59 PM
LuderCriS's Avatar
Default Re: why NOT to get that shitty AEM bypass valve (LUDE-a-cris)
ok i let my little bro step on the gas while i observe the bypass vlave and i poke it and i cud feel the air passing through. fawkk man its like i have 2 air coming in the filter and the bypass filter lols im getting a ram instead screw cai with bypass valve
Old May 21, 2002 | 11:50 PM
Legacy_CPA's Avatar
sick , glad I never put that POS on, too bad I wasted $45 buying that **** tho, anyone want to buy it??
Pandor
Jul 22, 2008 08:39 AM
lude_si_95
Oct 9, 2003 06:55 PM
F00LI0
Jul 21, 2003 10:42 AM
90TegRex
Nov 17, 2002 08:06 PM
Aaron M
Nov 11, 2002 03:27 PM
